by seeker1056 » Mon May 21, 2007 1:32 pm
Well i finally found time on this long weekend to get some work done on the truck.
Now have the POD's and the 666 spring installed.
What a difference to drive, tops out at 3385 rpm in all gears, easier to drive, and motor noise is half of what it was.
Things they don't tell you, lol, anywhere. If you get a ball socket type allen key, one does not have to move the pump to get at the back screw on the pump housing. If you look closely there is a slot in the finger that holds the tophat assembly. If u push the spring end thru it the whole thing comes out without having to try n fish around with needlenose to get the spring off the tophat assembly first. Same for reassembly, put the top hat assembly on the spring then push the spring though the slot and push down, instant hook up, no muss no fuss. The other thing they dont tell you is that the fuel pin must be full forward for the top to fit down on the base again. Removing 1 and 5 valve covers allows one to move the injector lines enough to get the injectors out without havin to completely remove the lines.
So, I re-indexed the throttle, installed the injectors, have the fuel screw seated at its deepest. By the way the old injectors, even though only have 25000 on them had at least one hole plugged if not two or three on some.
On a full power run on just the hx35 I have 60+ drive pressure, and 28 psi boost, and 1600+ egts. - not good!! Still 2:1
Tried adjusting the wastegate, but very little differnce. Man does this thing (hx35) HOWL/SCREAM from 22+ psi by itself.
Next I put the hx55 back on. Full power run nets me 48-50 psi boost, 60+ drive pressure, and 1400+ egts with 18 psi boost showin between the two chargers. so about 1.5:1
Second run blew a hose connector off between the chargers - bad clamp.
So ok, 50 psi compound is fun, but what is wrong with the hx 35 - is it possible it is junk? I cant push it any harder by itself, or drive pressure is pegged on the drive guage at 60+ and egts are in the 1600 range and climbin til i let off.
Thoughts anyone?
Thanx
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
