Turbo sizing and questions.
Postby PRINCETON_JAKE » Sun Jan 17, 2010 4:36 pm
Right now my truck has the stock turbo, its a 92 innercooled, 21cm exhaust housing. What size would the exhaust and intake wheels be? I want to change the exhaust housing, I have a 18cm non wastegated and a 12cm wastegated on the shelf, but i also want to upgrade the intake side, from what i have found, there is a 58mm and a 60mm available. What is a good combination for my truck? right now i can hit
24psi max, and 1400 degrees. I dont tow a lot, but when i do its usually big mud trucks. I also have bad compressor surge right now.
1992 cummins, 2wd, A518, WH1c, 60mm,12cm housing, fuel screws maxxed, fuel pin turned and ground, 3200rpm spring, big Amsoil air filter, 4" stack, timming bumped, piston lift pump, Bosch 190's, 18" Maxxi Hulk rims, and Nitto Terra Grapplers.
PRINCETON_JAKE
Postby KTA » Sun Jan 17, 2010 5:12 pm
A 16cm exh hsg will get you your best boost vs egt on a hx35/h1c turbo. As for your surge problem putting a bigger wheel in it will make it WORSE! Surge means the turbo is pumping more air to the engine than the engine can use. The H1c's do not have a Map Width Enhancment grove cut in them like the Hx35's do. If you can find someone with a lathe and a hx35 to measure off of you can cut the MWE grove in your compressor cover and eliminate your surge issue.
Postby PRINCETON_JAKE » Sun Jan 17, 2010 6:15 pm
Do any of the aftermarket compressor wheels/housings have the groove in them? Should I get a hx35, and forget about the H1C?
PRINCETON_JAKE
Postby Ace » Mon Jan 18, 2010 8:57 am
Yes, the H1C 60mm upgrades have MWE slots. Mine doesn't surge at all with a 12cm non-wastegated ex housing up to the max of 30psi I've seen out of it.
Ace
Postby PRINCETON_JAKE » Mon Jan 18, 2010 7:23 pm
I got the 12cm housing on today, wow what a difference, instant spool compared to the 21cm. The only problem I have is the down pipe is toching a metal coolant line, next to that big heater thing. Whts that thing called? I'm also putting on a single stack tomarro.
PRINCETON_JAKE
Postby PToombs » Tue Jan 19, 2010 6:31 pm
That line goes to the trans heat exchanger. Better move one or the other or it'll get ugly. ;)
