Ok, What is your goal(s) for your truck?
Postby oldestof11 » Tue May 08, 2007 1:33 pm
I want to know everyones goals. List everything that you can think of.
Mine are make it look nice but have a raging bull under the hood :twisted:
No cancer
Chrome kick plates
Flatbed with diamond plate boxes under for storage
5" turnouts (maybe but we will see) :D
450hp/??tq but still streetable
Have it to do some truck pulls and win with that old piece of junk :oops: :twisted:
Blow any amount of smoke to even smog the tailgaters at night :twisted:
Max the VE to its full (See if one day it could be capable of pumping 500+hp) :twisted:
NO Alcohol
Do burnouts in any and every gear!
Very distant future goals are to retire (if thats really gonna happen :roll: ) it as:
500+hp/1200#tq
35" Mudders
8" turnout stacks
Twins
Traction bar
Front weights
Steering stablizers
Eagle 058 Alloys
BIG bumper in the front
Alcohol
Nickname Raging Bull (said with a certain awe and respect)
Lets here yours!
Postby meby » Tue May 08, 2007 3:35 pm
My goals if I keep it are as follows:
400HP on the VE ( Enough to beat most vehicles on the road) :lol:
Edm Injectors
Better Huffer
Fully splined NV-4500 with appropriate single disc clutch
water/meth optional
Port and Polish?
no rust
Needs to look like a stock truck on the outside ( Stealth till the smoke rolls :twisted: )
Nerf bars
Nice Seat cover
I-pod dock with a good sound system
Lund Stainless Bug sheild
New Flatbed (Light weight?)
All Leds
Some BRIGHT backup lights
manual lockout hubs
255/85/16 All Terrain tires
What i've done to get there
Some ve mods
4" exhaust
Gauges
hi flow filter
advanced timing
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby swank » Tue May 08, 2007 5:13 pm
i'd like to chop mine 8-12" and paint 'er flat black.
full air ride all the way around. (no metal springs at all)
rebuild engine (blowing the wrong color smoke these days)
that should keep me busy for a while.
truck
swank
Postby gman07 » Tue May 08, 2007 6:09 pm
I'd like to push the limits of the VE someday (once I'm out of college and making some decent money). I'd also like to have a way to log data from a variety of sensors and eventually develop a chip to control variable geometry twins, or at least a good variable geometry single... but that's a ways down the road. Making it look decent would be good too.
1992.5 W250 pump tweaked, straight pipe, gauges, 3200 Gov. spring, AFC lever partially ground, timed at 1/8", Fuel pin ground, BHAF, HTT Stage IV H1C/E 60/12wg (ported), Transgo shift kit, KDP clothes-hangered, 202,000 miles - 36psi, 1250°
gman07
Postby swank » Tue May 08, 2007 6:23 pm
gman07 wrote:I'd also like to have a way to log data from a variety of sensors and eventually develop a chip to control variable geometry twins,
oh really??? what are you going to school for? i don't know if you're aware, but i have all the makings for the twins part of that equation. whole bunch of turbos and an E/P regulator.
truck
swank
Postby gman07 » Tue May 08, 2007 6:27 pm
I plan to major in Mechanical Engineering, but maybe take some courses in aerodynamics as well. I'd like to end up working for either a diesel engine company (Cummins of course 8) ) or a turbo manufacturer. I'm also considering Electrical Engineering; I'm not sure yet.
gman07
Postby Begle1 » Tue May 08, 2007 8:04 pm
I don't believe in the concept of "goals". One cannot live with the placement of goals in front of them, or one will procrastinate and not do. What one must do is be progess, and make progress do to who he is.
I'm building a drag truck over on this end. My goal is to have enough power to make a lock-up and overdrive a liability.
Currenty looking for an S110 axle, as per KTA's recommendation, to get some limited slip action and disk brakes.
Planning on building a DIY nitrous kit to get off the line. Gonna put the nitrous jets in the BHAF box I'm building.
Looking for a 12cm w/g housing.
Got a Goerend's TC installed and a Hughes manual valve body on the bench.
Intalling a WVO system for the last two years. Got it all but the filters. Planning on running #6 Diesel in it.
Installing 5 inch sideliners at the beginning of Summer.
Going to have to install a water injection system to make up for the intercooler; like gman, I want mine to be dynamically controlled and programmable based on boost pressures and EGT's.
Tweak my pump to it's fullest, get some injectors after I get my twins. Nothing fancy there, just do it on the cheap with the stock turbo on top and a 3HTB.
Probably will never be satisfied without a bigger pump. But I wouldn't install a P-pump in a first gen. Actually I might, along with a back-yard propane system to compensate for the lack of variable timing, as the P-pump would probably be better suited to running #6... But, I'm hesitant to do that.
In order to make up for the lack of overdrive, I'm planning on boosting the powerband as high as I possibly can. So a cam and whatever springs KTA's running. And Diesel fumigation in the intake.
And the woman in the passanger seat would be nice to.
Ya'll know that I haven't had consensual contact with a female in 10 years? Ever have those thoughts that kind of surface and sink for years on end, but you don't really dwell on. Well, I had one. In second grade, the little Mexican girl with the doe eyes, straight black hair and pale skin. Anna-Leigh Sanchez liked me. She let me hold her hand once in the cafeteria, after she flirted with me by stealing my fruit roll-up. So she sat there looking at me with the fun and the mirth and the trust as I punished her like the bastard I am by twisting my hands about her wrists to burn her. And I saw that joy and intimacy in her eyes turn to fear and disgust, and I saw the tears, but I hurt her on purpose and wouldn't stop until I saw them. So I don't know why I was distraught. And she went and told the lunch supervisor, and I was told by God herself that "I never want to see you put your hands on this girl again". I was never friendly with Anna-Leigh again, but she came to be all women. And so my subconcious, indirect underminings of relationships; my self-imposed social alienation, my chronic ineptitude with females, my pornography addiction, my unhealthy attraction to my truck; how much of it stems from fear of presenting my true sadistic, uncontrollable, unempathetic identity to my fabricated identity of lies and superficiality!
Postby CAJUN 93 » Wed May 09, 2007 6:16 am
uuummmm, ok :shock: begle, that was interesting reading.
well, to greatly oversimplify it, i just want a really comfortable truck that looks good with enough power to efficiently pull a camper trailer so me and the wife can see this great county we live in. i dont think thats asking too much.
CAJUN 93
Postby bgilbert » Wed May 09, 2007 10:42 pm
Short term goal for the 89: break 500hp with the single charger I have now. Long term goal is 600hp. I think I'll be happy then LOL, not likely, it never ends as Kinison said.
Bill Gilbert
bgilbert
Postby KTA » Thu May 10, 2007 8:26 am
You have Saturday to break 500rwhp, you better have been tuning on that thing!!!
Postby Greenleaf » Thu May 10, 2007 4:19 pm
I'd like to be able to take one of mine on a road trip sometime this summer.
Greenleaf
tech specialist/mod
Postby PToombs » Thu May 10, 2007 5:51 pm
Scott, you have until October to get ready! :lol:
I'm trying to make mine relatively rust free, (for a while). Respectfully fast, powerfull, (300-400 HP), hot rod diesel! I want to be able to put my wifes 7500 lb tractor on the trailer and go to a pull or a show, and get there in 1 piece and in style! Oh, and beat any strokers or maxis I see on the way!
Postby bgilbert » Thu May 10, 2007 11:58 pm
KTA wrote:You have Saturday to break 500rwhp, you better have been tuning on that thing!!!
LOL, heck that one ain't even put together yet :evil: ! Still waiting on JR to fab me that crossover pipe. I'll be driving the auto truck Saturday. Hopefully I can hit 350rwhp with that one:D.
bgilbert
Postby Greenleaf » Fri May 11, 2007 8:32 am
[quote="PToombs"]Scott, you have until October to get ready! :lol: /quote]
I don't believe I'll be there this year. You's guys will all have rust free 500 HP units from the above posts. I'd feel out of place and inferior.
I'll just set home and watch re-runs of "Little House" and "Walker Texas Ranger"
:cry: :cry: :cry:
Greenleaf
tech specialist/mod
Postby Cschafer » Fri May 11, 2007 10:03 am
I'd just like to be able to drive it more than 2000 miles without catostrophic driveline failer.
I want to slowely take a run at highest horsepower ve truck and see what can be done with it :twisted: . When I get tired of that I'll swap in my other built 96 motor with a p-pump and turn it into a full on pulling truck. Those are the plans anyway. I beter get out back and water the money tree :wink: .
91 w250 wrecker
Cschafer
