fuel pressure regulator
Postby Remps » Wed Jun 23, 2010 7:32 am
I want a fuel pressure regulator that is capable of boost referencing from 10-70 psi, but is capable of running a fixed 15 psi. Any names or part numbers? My $20 electric LP is starting to take a dump, so I want to use my 7.3 fuel pump, but it makes 80 psi. I will also replace the draw straw and fuel line, and get a FP gauge.
Re: fuel pressure regulator
Postby oldestof11 » Wed Jun 23, 2010 5:26 pm
The Mallory 4307M is boost referenced if you hook it up. But the thing is the 4-25 psi limit.
Postby lectro_static » Fri Jun 25, 2010 7:55 am
oldestof11 wrote:The Mallory 4307M is boost referenced if you hook it up. But the thing is the 4-25 psi limit.
I believe that 4-25psi is the base pressure and when you run boost into it it will raise pressure on a 1:1 scale i.e. 15psi base at 55lbs boost equals 70psi fuel pressure. Hope that makes sense.
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Postby Remps » Fri Jun 25, 2010 11:29 am
Ah, perfect! That is the regulator I will look into getting then. :grin:
Users browsing this forum: No registered users and 62 guests
