3 for free air ?
3 for free air ?
Postby BC.livewire » Mon Jun 28, 2010 4:23 pm
ok I have a intercooled 91 with 5speed and I'm thinking of the best ways to get free air
I so happen to have 2 free VGT turbos sitting hear wating to be use
yes yes I know that most guys that run twins start off with huge turbos but I'm thinking keeping the stock turbo as the prymairy-- furst turbo off the manifold --- than run the 2 VGT's as sencendairys
I would add a exturnall wastegate from the manifold feeding the vgt's and would be looking for 50psi max
tell me what you think good or bad
BC.livewire
Re: 3 for free air ?
Postby lectro_static » Mon Jun 28, 2010 5:29 pm
Which vgt turbo is it? If its hte he351ve or the 431 either will do great as a single. I have been toying with the idea of my 351 and a 551 twin set up running vgt on both, I just think it would take a long time to tune it.
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Postby BC.livewire » Mon Jun 28, 2010 6:11 pm
as far as I know they are the smaller 351
wow that is a more possative ancer --- good that means I'm lurning moer about this commins motor
well my thinking is that thes 3 turbos are what I have
and the stock turbo has a huge hot side " that is why everyone upgrades to a smaller snail with a inturnall wastegate "
so I'm thinking to what oversized turbo but preboost the ait going into it
BC.livewire
Postby oldestof11 » Tue Jun 29, 2010 1:16 pm
I want to do real twins on my truck. Split the manifold and put 2 VGT's on it...
Postby BC.livewire » Tue Jun 29, 2010 2:25 pm
that could be done too
BC.livewire
Postby BC.livewire » Fri Jul 02, 2010 11:32 am
been doing more reading
my turbo has the larg 21mm exhoust snail so if I add a larger 61mm intake snail that I can get for $250ish --- this would make a good sized hybred turbo
than I could use one og the VGT turbo (just one turbo) as the primairy ( the turbo mounted to the exhoust manifold ) --- this use the now hybred turbo as the sencendaity
BC.livewire
Postby oldestof11 » Fri Jul 02, 2010 12:04 pm
The 60mm upgrade is ok for mild mods. You would be better off getting a s400 for a couple hundred more.
Users browsing this forum: No registered users and 62 guests
