Richie O wrote:If you don't mind haze and lots of smoke then go with the 6x16's.
projectworkstock wrote:Richie O wrote:If you don't mind haze and lots of smoke then go with the 6x16's.
do you think they will work alright if i turn the pump down or am i on the verge of melting the pistons if i go with the 6x16s with the he351
Richie O wrote:If you want the big sticks in the end get them first and adjust your fuel screw to the turbo you have. You can have as little as 180 horses all the way to 500 plus with a set of 6x16's. Like I said before the 16's run great, just hazzy.
link to a cold idle vid of my 93.
http://www.youtube.com/watch?v=nePEwhQjSQ0
how would these do if i hooked to the sled, to hot and dangerous, or hot but nothing to worry if i dont hold it there all the time
BC.livewire wrote:
wile reading I see every one upgrade the fuel furst --- but just makes heat
wouldn't be better to upgrade the air "turbo" side of the motor furst ? than add fuel whin EGT's cool off
AHineman wrote:
Hey Richie-would timing help or hurt the haze? Mine don't haze anywhere near as bad as yours, but I have mine timed to the head right now.
