Newb looking for easy idea...
Postby scooter450r » Mon Aug 02, 2010 10:18 am
Hey guys Im the newb... So kick me while you can! :)
Ok I just bought my first Dodge... Its a 92 250 with a blown trans... The Idea for the truck is to abuse it! Race/pull/snow removal...
After I get the trans in and done where should I start on building power? It has already had the fuel pressure reg reclocked and turned up, K&N and rusted off exhaust under the bed... Id like it to be around 350-400 or more without getting too crazy! Im building front and rear traction bars. I was plannin 5" exhaust. I have a 95 Ford F350 dually with Im guess'n 350HP at the tires... I want it to be alot faster than it... Well let me know what you guys have done in the start to get them up and smoking! Thanks!
scooter450r
Re: Newb looking for easy idea...
Postby oldestof11 » Mon Aug 02, 2010 1:03 pm
What do you mean "reclocked and turned up"?
You can beat that PS with just around 300 at the wheels since it is a LOT (it would way near 5500 lbs...) lighter.
Postby scooter450r » Wed Aug 04, 2010 5:43 am
Well thats what te guy told me when I bought it and seeings how I dont really know much about these thats I put on here... Im guess'n he meant the fuel pin was turned or "reclocked" in some peoples words and "turned up" meaning they adjusted it where the jam nut is...
Basicly it looks like I will get a fuel pin and some injectors for now and should have enough power to start with...
We have a exhaust shop so Ill make up my own exhaust and plumbing to get cold to the air filter and after adding a intercooler to my old ford it really aint that hard so I might go with a 6.0 powerstroke intercooler and make my own 3" pipes.... Thats the plan for now.... Oh and building the new tranny
scooter450r
Postby ahale2772 » Wed Aug 04, 2010 5:56 am
make sure u have enought fuel to ur pump before u start turning things up and using it faster than u can supply it, get some gauges on her too i gaurentee after a few months ur attitude will trun from "beat the hell out of her" to "sell the ford"
Postby BC.livewire » Wed Aug 04, 2010 6:57 am
modds in order furst to last
gauges - better liftpump - tuning of EVpump - exhoust - injctors more tuning of EV pump
tighten head bolts - better turbo - better IC -- by than your clutch will be toast and or auto traney
BC.livewire
Postby scooter450r » Wed Aug 04, 2010 10:09 am
I doudt Ill sell the Ford... Its a crew cab 2wd dually that I pull a 30' fifth wheel and 14' car trailer full of toys... We usually have 5 people and Im exactly at the 65' foot in length mark... The dually has its own purpose and have alot of $ tied up in it! Ya I should of maybe did some more homework before buyn but it was a good deal at the time and fit my budget... The Ford runs really good specially of the line! The ford is alot more expensive to build thats for sure!
scooter450r
Postby scooter450r » Wed Aug 04, 2010 11:00 am
What lift pump would you guys go with? Also what kinda of power will the truck make by crankin up the fuel and nothing else? I am tryn to limit the budget for now... I have to buy a trans and tires to start...
scooter450r
Postby 1STGENFARMBOY » Wed Aug 04, 2010 11:31 am
You can count on 100 extra, 300hp is pretty easy, the next 100 is expensive and very hot egt's if you
don't spray somkind of drugs in it.
Dar
Postby ahale2772 » Wed Aug 04, 2010 12:06 pm
do the 2ng gen lift pump there are all sorts of threads about it on this site
Postby oldestof11 » Wed Aug 04, 2010 1:16 pm
I put on a Walbro 392 with a Mallory 4307M regulator set at 16psi.
I saw you have a 92, my list would be:
Gauges-Lift Pump-Tuning-12CM exhaust housing-Injectors-60mm compressor
That should give you about 300-320 and a nice scooting truck.
Postby scooter450r » Sun Aug 08, 2010 6:46 pm
Ok guys I have a tranny coming and should be here tomorrow... Im gona check it over good before putting it in but was wondering how much power they can take stock? Also can you tell by looking at the outside of a torque converter if its anything special? Thanks!
scooter450r
