oldestof11 wrote:The 5250 rpms is a TDR myth.
Peak torque can be changed.
Begle1 wrote:Somebody needs to get all scientific and stuff and graph these springs' tension verse their given length... See what kind of fueling curve the actually give per RPM, to see if a 3200 RPM spring does actually act harder on a governor than a 4000 RPM governor spring...
Just need a caliper and a newton gauge thingy...
For an all-out performance stand-point you want a stiff spring that stays stiff right up until the RPM you want it to cut-out, right?
Although doesn't Hook's law kinda mean the springs' curves will all be linear and that you just want as stiff a spring as possible that is long enough to still give you full fulcrum lever travel?
