confused
confused
Postby truckwrench1 » Thu Sep 09, 2010 7:03 pm
ok faairly new to the site trying to grasp some of the lingo checked search but couldnt find a definative answer the s300 and s400 are made by who and what power levels do they support :?: :-?
truckwrench1
Re: confused
Postby AHineman » Thu Sep 09, 2010 7:30 pm
They are made by Borg Warner (Schwitzer). S300 and S400 are the names of the frame or series of the turbo. For example an S300G is a 57mm s300. Companies like Industrial Injection or High Tech Turbo, etc. take these and put bigger compressor wheels/housings or exhaust wheels in them from other turbos in the S300 series. If someone says they have an S362, they mean an s300 with a 62mm compressor wheel. The S400 series is a heavier framed line of turbos than the S300 line. Saying you have an S471 means an S400 with a 71mm compressor wheel. Different companies modify all of these turbos, but I think most start with stock Borg Warner parts.
http://www.airwerksboosted.com/Files/BW-AirWerks-Performance-Catalog-2010.pdf
This pdf has some good info...
Re: confused
Postby truckwrench1 » Thu Sep 09, 2010 7:43 pm
thanks makes so much more sense now :D
truckwrench1
Re: confused
Postby Mark Nixon » Fri Sep 10, 2010 7:05 pm
I agree, makes SOOOO much sense now.
