Valet switch?
Valet switch?
Postby seeker1056 » Mon Jun 25, 2007 3:57 am
What is a Valet switch and how/where does it get installed?
thanx
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby wannadiesel » Mon Jun 25, 2007 2:28 pm
A valet switch controls a solenoid valve in the boost line between the manifold and the AFC housing on the pump.
Best dyno: 408/844
wannadiesel
diesel guru
Postby Philip » Mon Jun 25, 2007 9:09 pm
That solenoid would be used to drop the boost reference signal for more fueling. This would slow the truck down a lot.
But the other side of that coin is. If you don't trust someone enough without the switch turned on. Why let them in the truck in the first place.
Postby wannadiesel » Tue Jun 26, 2007 1:55 pm
If you have enough fuel it doesn't slow you down a lot. I run mine in valet most of the time because it runs cleaner and it has plenty of power - and I never have to look at the pyro.
Best dyno: 408/844
wannadiesel
diesel guru
Postby k5cowboy » Wed Oct 17, 2007 10:23 pm
how do you turn it on and off?
k5cowboy
Postby rbrettctd » Thu Oct 18, 2007 10:17 am
Simple toggle switch controlling the solenoid.
Randy
rbrettctd
