Ole' Blue wrote:Cool, thanks. Our 93's are pretty similar, other than your 6x16's and the GDS upgrade. How do you like the GDS?I guess its ok. Never drove the truck whith the stock set up. I put it on while I had the truck tore down Where's your fuel screw at? 4 full turns out from max 6x16 seems like a large injector for your HP range, are you always watching the EGT gauge?There is no sense to watch it. Its always pegged. Do you ever tow with that truck?Once and a while just for giggles
lectro_static wrote:Look into a G-tech you can buy them from summit racing, jegs, ebay etc and they are fairly close and it just plugs into your lighter socket so its easy to change trucks to check your buddies
....its a marvel my turbo is still in one pieceUsers browsing this forum: No registered users and 43 guests
