smoke switch for our trucks on youtube
Postby 91bluecummins » Thu Oct 28, 2010 6:33 pm
what do yall think about this boost fooler / smoke switch contraption on youtube that this guy made for our 12 valves it looks pretty liget please comment about it
92 cummins W250 extenged cab (The Goat) project truck
90 cummins W350 single cab dually flat bed 5 speed, he351ve 62mm
1959 chevy Apache 4bt cummins 4 speed
91bluecummins
Re: smoke switch for our trucks on youtube
Postby Richie O » Thu Oct 28, 2010 6:35 pm
I already have a smoke switch. My right foot. :D
Postby ellis93 » Thu Oct 28, 2010 7:07 pm
How about a link to the vid?
Postby 91bluecummins » Sun Oct 31, 2010 10:55 am
91bluecummins
Postby 91bluecummins » Sun Oct 31, 2010 11:41 am
what kind of solenoid valve is that i cant find one anywhere whats the name of it
91bluecummins
Postby PToombs » Sun Oct 31, 2010 5:53 pm
It didn't smoke much more on the 2nd pass than the 1st one. When he was climbing the hill the 1st time he had boost, you always do unless you're letting off it. Waste of time and energy IMO, I can do the same thing just by stepping on it hard.
Postby ellis93 » Sun Oct 31, 2010 6:05 pm
I'm not trin to be a butthole but I don't see the return in all that work. If ur gonna make smoke why not just spend the 100$ for one of those fancy fuel pins. People have them and still get good milage don't they.
Postby SNOOT » Sun Oct 31, 2010 6:45 pm
Richie O wrote:I already have a smoke switch. My right foot. :D
http://www.youtube.com/watch?v=Z0m7bSCR_Vg
1993 W350
SNOOT
Postby JBradley500 » Sun Oct 31, 2010 7:19 pm
looks like a lot of work and ingenuity to do the exact opposite of what most of us are trying to do. ehh, what do i know.
92 W250- K&N Filter, Smoke Screw Adjusted, Synthetic Transmission Fluid.
340hp/662tq (8/24/12)
JBradley500
Postby ellis93 » Sun Oct 31, 2010 7:20 pm
:lol: watchin a dually burnin tires never gets old. Your the one that does the 360s too huh?
Postby SNOOT » Sun Oct 31, 2010 7:25 pm
ellis93 wrote::lol: watchin a dually burnin tires never gets old. Your the one that does the 360s too huh?
I did one today and just last week....
http://www.youtube.com/watch?v=fZegre9X_zE
1993 W350
SNOOT
Postby Richie O » Sun Oct 31, 2010 7:33 pm
All he is doing is making a remote " smoke screw " adjustment. I am sure it will work better with a aftermarket pin. Put that with an aftermarket pin as well as a valet switch and you would have 3 options. ( low fuel settting " valet mode ", regular, and full fuel.)
Postby ellis93 » Sun Oct 31, 2010 7:38 pm
Freakin cool. Its funny siht watchin that big sas truck doing that. 8)
Postby JQmile » Tue Nov 02, 2010 3:49 pm
x2...check out how well a 62mm turbo cleans up my 6x16s and 14mm pump :mrgreen:
http://www.youtube.com/watch?v=SKscUjeBmIo
JQmile
Postby Kiddspeed » Thu Nov 04, 2010 1:25 pm
(Read the post and posted this)
Ok so my thing is with the "smoke screw" is with the TPS model trucks if you do the dial to change out/get rid of tps. Couldn't you just turn the dial to shift in to od at a really low rate of speed if your pump is turned up then it should smoke plenty because it would be like a manual truck up shifting at a low rate of speed. There's you smoke screw and tps delete! Sorry non IC guys that's the price you pay for having bigger injectors and no problematic tps.... :mrgreen:
Kiddspeed
