HTT Compressor Wheel
Postby cootz » Sun Jul 08, 2007 9:41 pm
So I've got my Stg 4 ready for install,but I'm a little hesitant just yet. The compressor wheel has what looks like machined marks on it,I'm assuming for balancing purposes, but really looks almost like a butcher job. On the back side there is a small indented machined groove. On the front side (the blade side) there is metal missing from the centre section where the nut will be holding the wheel; it looks as though it was machined off too. For those of you with upgraded wheels, is this normal? Not sure I would like an unbalanced wheel in my engine just yet. I'm going to give HTT a call tomorrow, but thought I'd ask here too.
Preview
'93 Dodge W250 LE ext cab
Manual trans. Getrag overfilled
Autometer boost & pyro
BHAF w/ Ol' Smokey Mount
3200 gov spring, BD fuel pin, timing bumped
IP has been seriously violated
Butcher block on the front
240 000 km's
cootz
Postby KTA » Mon Jul 09, 2007 11:32 am
Sounds like typical balancing marks to me. 8)
Postby 90firstgen » Thu Jul 12, 2007 5:29 pm
Yessir. Those are balancing marks
1990 2x4, 3/4 ton, Getrag, Cummins N/I
3200 Spring
Full Fuel Screw maxed (+/- 4 turns)
Injector rebuild with bigger nozzles
1/8" Timing bump
Airflo Intake
HTT 56mm Compressor
14cm Wastegated Housing
Stan's 4"
90firstgen
Postby PToombs » Sun Jul 15, 2007 4:15 pm
I just got home from vacation, and mine was waiting for me. The wheel looks just like you describe. I'm sure it's balanced and ready to go.
