Ya'll see the new fuel screw?
Postby Begle1 » Sun Jul 08, 2007 9:52 pm
Check it out...
It's a hex head! (And a part number...)
Did the newer trucks have the hex head, or is it something Bosch modified after '93?
Postby bgilbert » Sun Jul 08, 2007 10:46 pm
Yep somewhere along the lines, maybe when they became intercooled, the fuel screw received a 6mm hex head instead of the stupid slotted head. What did that cost you?
Bill Gilbert
bgilbert
Postby Begle1 » Mon Jul 09, 2007 9:23 am
I got it for the low, low price of 20 dollars.
I wish that were some sort of ironic hyperbole, but it isn't. The damn thing literally costs $20.
Man, you got ripped off!
Postby Ace » Mon Jul 09, 2007 12:20 pm
$15.47 at the place I get Bosch stuff here in Denver. :D I went ahead and ordered one right away, just to see if it's any longer than the one I have now that don't seem to want to go in all the way. Also, so's I'll have a spare if I end up botching the weld job to extend the tip of the original. :oops:
I discovered my fuel screw was already almost all the way in when I tried turning it in again to see if I could regain the couple pounds of boost I lost with the new Powerstroke intercooler.
Ace
Postby Begle1 » Mon Jul 09, 2007 2:19 pm
The threads are 8 mm, 1.00 pitch.
I played with the idea of threading a small piece of all-thread in there, and then putting an O-ring or copper washer in between the side of the pump and the nut locking in the all-thread.
I have a hunch that it really wouldn't want to seal without the fancy O-ring-in-the-threads, though.
