The 5" duals have been started
Postby IowaCummins » Sat Nov 27, 2010 1:22 pm
this morn i started the process of 5" turbo back to Duals straight out the back. down pipe is almost done and kinda figured it out to get around the transfer case and cross member with out beating the pipe. hopefully a video will be posted soon :D
IowaCummins
Re: The 5" duals have been started
Postby ellis93 » Sat Nov 27, 2010 3:57 pm
Where did you buy your tubing at.
Postby IowaCummins » Sat Nov 27, 2010 5:50 pm
one of my buddies works at a local truck salvage yard so i got all used stuff that was basically take off for bigger for free
IowaCummins
Postby ellis93 » Sat Nov 27, 2010 6:38 pm
:D lucky u. I want to do mine out the sides with 3" w/ 4" tips. Sihts high.
Postby Tacoclaw » Sat Nov 27, 2010 11:50 pm
I'm not sure if you literally meant "straight out the back" or not, but I believe your tailgate will get sooty if that's the case. I know on RC and Blazers. you have to have the pipes out the sides or the exhaust end up coming in the back window. :?
Postby IowaCummins » Fri Dec 17, 2010 11:12 pm
Mmmmm 5" duals look sexy on a black truck! Lol well I have the rear half done and the front half.
Meaning I have 5" to the back of the cab,
And the duals them self and the diverter box in, now just put in the 4' section inbetween!
Oh Btw 5" exiting right behind the cab angleing up with no bed sounds amazing.
found out my rear bumper is 1/4" C channel with 3/8" plate welded in to the back side of it, hard time cutting you say? Well my Miller 2050 says other wise! Lol two perfect circles in about 2 minutes, every time I use it I fall in love even more
IowaCummins
