Cam Grinds
Cam Grinds
Postby 2muchtq » Sun Jul 15, 2007 3:55 pm
I can get a cam reground from MUCH less than an aftermarket.
Is there ANY specs on a decent cam floating around?
Heck... I'd even settle for a spec sheet on the factory ones. I just need a starting spot.
Thanks
Mark
PS... I have a cam with a couple journals in sorry shape. Can a shop build them up and turn them to make it work?
2muchtq
Postby dpuckett » Sun Jul 15, 2007 6:16 pm
I wouldnt want to have the journals built up and ground down.
DP
Postby mhuppertz » Wed Jul 18, 2007 3:33 pm
Regrinds can work fine, but since you are going to have to change out lifters anyway it's safer to go with a new one, especially if it's a work truck as well as a play truck.
mhuppertz
Postby 2muchtq » Wed Jul 18, 2007 7:02 pm
BUT. Unless I want to pony up the billet and have one custom made... I am stuck with aftermarket companies. While I am sure they all offer a good product. I can get three cams ground for what the aftermarkets cost.
I want to play with overlap... cam timing.... stuff like this.
I have a few theories about high timing numbers in trucks that will take a cam that I need to have made and set to my idea of proper timing. (dont worry... pistons will be decked to allow valve clearance)
Basically... I am NOT building a daily driver... I want the fastest first gen VE pumped truck down the 1/4 mile.
2muchtq
Postby KTA » Wed Jul 18, 2007 7:06 pm
Buy a stock 12v cam core off ebay and get it ground to whatever specs you want.
Postby 2muchtq » Wed Jul 18, 2007 8:00 pm
The stock specs are what I am looking for.
Then... a decent starting point. From there I would like to play.
Thanks
Mark
2muchtq
Postby KTA » Thu Jul 19, 2007 6:44 am
Who ever is going to do your grinds should have a cam doctor and can check what the specs are on a stock cam for you provided of course you send them a good core to check. The other alternative is to take a degree wheel and a dial indicator and check it yourself, but I have found that method to be very difficult to get good repeatable results.
Postby 2muchtq » Thu Jul 19, 2007 7:23 pm
Thanks. I might just go that route.
2muchtq
