by JBradley500 » Wed Dec 22, 2010 3:18 pm
id back the smoke screw off until its not touching the fuel pin anymore. people run their starwheels at different places but i run mine tight to try and help turbo spool and keep smoke down. some people run them loose to make smoke with the fuel come on harder. its probably something you should mess with to find the best place for you. ive tried everything from stock, bottomed out, 4 turns up and now im up to the top of the threads. i am no expert but i think 4 turns is a good general area when trying to keep smoke down because on my pump that was as high as i could get it before the fuel cone's travel was affected by coil bind. any higher than that and you dont know whats really happening unless you have your pump top off to mess with the levers as youre doing the adjustments. i took my pump top off and found out how high i could move the spring before my afc fueling was being limited. thats how i found out that aftermarket fuel pins are cut so deep that the pump cant take advantage of the depth.
again, im no expert. i just typed that all out because im bored.
92 W250- K&N Filter, Smoke Screw Adjusted, Synthetic Transmission Fluid.
340hp/662tq (8/24/12)
