pod injectors non ic in an ic truck
Postby fourwheelininajeep » Tue Dec 14, 2010 2:52 pm
I have a set of pods that I got for my 90. Im going to better quality injectors as I dont like the smoke and outrages egts but I want to know if they will fit in my brother in laws ic 93.
I read a thread a minute ago about no ic injectors not working in an intercooled truck because of the bowl in the piston being wrong for the fuel spray. If this is true the fuel atomization would probably be terrible and not help him build more power at all. Im assuming that is all that means, if someone could elaborate more on what would happen I would appreciate it.
1990 dodge w350 cab and chassis frame single rear wheel 99000 miles with chrome stacks between cab and bed paid 1300 for it after a years worth of work i got to drive it
fourwheelininajeep
Re: pod injectors non ic in an ic truck
Postby chrislib » Tue Dec 14, 2010 5:38 pm
If they are 7mm nozzles they`ll fit fine but still have all the POD drawbacks.
It`s not about how hard ya hit...it`s about how hard ya can GET hit and keep movin forward.
93 W250 CC 4x4, Auto,7x010`s, D-Zilla/16cm, 5in exh, BHAF/Smoky...don`t call it ratty, that`s patina son!
chrislib
Postby fourwheelininajeep » Tue Dec 14, 2010 6:07 pm
How do I tell wether there 7 or 9
fourwheelininajeep
Postby 913 Cummins 89 » Tue Dec 14, 2010 6:37 pm
i belive that pods only came in the 7mm option to put them into a non i/c truck you had toget adapters
913 Cummins 89
Postby soggy » Tue Dec 14, 2010 6:53 pm
Try putting them in the IC truck, if they fit they are 7mm. If not they are 9mm. Or you could measure them, or you could see if there are adaptors to make them work in your 90.
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby Richie O » Tue Dec 14, 2010 7:06 pm
Don't " always " go on if they had the adapter or not. It would not be the first time I have heard of guys running a 7mm injector in a 9mm head with no adapters. :shock: They say " it will carbon up in no time ". 8)
Postby Smokem1 » Tue Dec 14, 2010 11:54 pm
Adapters are not "required", soot build up between the nozzle shank and bore may increase the amount of effort needed to pull them from the cylinder head however. The POD is 7mm shank, the problem is they use a 160 degree cone angle, which is not ideal for the smaller Non I/C piston bowl design.
Smokem1
Postby KTA » Thu Dec 16, 2010 8:37 pm
I think you got that backwards. The NON-IC engines have the big bowls for the 155 deg injectors and the IC engines have the small bowls for the 145deg tips.
Postby 913 Cummins 89 » Sat Dec 18, 2010 2:07 pm
i always thought you needed to run the adapter. but is there any other prolems with out running them also how will they seal with out the adapters as they act like sealing washers to
913 Cummins 89
