Non IC injector ?
Non IC injector ?
Postby 5.9 Fan » Wed Dec 29, 2010 8:43 pm
I am p pumping my 1st gen and swapping a 96 head also. I was wondering if any of you guys knew where I could get a set of 5x0.014's made so they have the same spray angle as my stock non IC injectors. TIA
1990 W250 Regular Cab p-pumped, 022 DV's, 4k gsk, 100 plate, 7x10's, o ringed head, arp studs, airdog, currently under surgery recieving getrag with southbend DD and hx35/40 over s475 twins
5.9 Fan
Re: Non IC injector ?
Postby delinquent » Thu Dec 30, 2010 12:18 am
Stay with the 145* spray pattern.
delinquent
Postby delinquent » Thu Dec 30, 2010 12:19 am
Oh yea, Contact "Smokem".
delinquent
Postby oldestof11 » Thu Dec 30, 2010 1:18 pm
Stay withe the 145* injector. As long as the spray pattern is within the bowl (Your's is made for a wider 155* angle), it will be fine.
The advantage you now have is the ability to advance timing a LOT and not worry about it burning the ridges of the piston, which causes melt downs and gouged walls.
Users browsing this forum: No registered users and 57 guests
