JQmile wrote:I would get an intercooled model
fatty wrote:The injectors and turbo for 400 hp will cost that much or more. And then you need studs, springs, injection pump parts, lift pump etc..
SNOOT wrote:fatty wrote:The injectors and turbo for 400 hp will cost that much or more. And then you need studs, springs, injection pump parts, lift pump etc..
Transmission work and torque converter..
Richie O wrote:
So, when you gonna intercool yours? We are all waiting.
theshark wrote:Is the OD trans as strong and as cheap to build?
What we looking at mpg wise as a difference. Just a ballpark is fine. probably 70/30 city/highway.
i would think 400 is easy to hit right? At under 5000 pounds it should be peppy and fun to play around in. Maybe walk a few mustangs and newer trucks.
