Links
Check here first for commonly discussed topics!
Moderator: BC847
Links
Postby Richie O » Thu Mar 17, 2011 12:24 pm
Pictures
Picture only thread ( no text ) http://1stgen.org/viewtopic.php?f=10&t=3944
Picture thread with text allowed http://1stgen.org/viewtopic.php?f=10&t=3719
Photo shoot TDR 2011 ( great write up about the plant ) http://1stgen.org/viewtopic.php?f=15&t=10652
Video links
http://1stgen.org/viewtopic.php?f=10&t=10660
Engine:
Cummins B-Series Engine Torque Specifications http://1stgen.org/viewtopic.php?f=1&t=9116&start=0
KDP repair ( killer dowel pin and case bolts ) http://1stgen.org/viewtopic.php?f=22&t=7233
VE Injection Pump Reseal viewtopic.php?f=1&t=17695&p=171618
Chassis
Rear disc-brake conversion: http://1stgen.org/viewtopic.php?f=2&t=15892
Transmisssion:
NP205 twin stick project. http://1stgen.org/viewtopic.php?f=3&t=11255
A518 info http://1stgen.org/viewtopic.php?f=3&t=11447
The good stuff:
How to make a valet switch http://1stgen.org/viewtopic.php?f=1&t=8096
Injector chart http://1stgen.org/viewtopic.php?f=4&t=1363&start=0
Injector breakdown http://1stgen.org/viewtopic.php?f=4&t=7418
Stock injector specs and types http://1stgen.org/viewtopic.php?f=4&t=6793
Piston lift pump info http://1stgen.org/viewtopic.php?f=4&t=7885
Twin turbo ideas, pictures http://1stgen.org/viewtopic.php?f=4&t=8875
Fuel screw adjustment ( full power screw ) http://dodgeram.org/tech/dsl/more_power/Power_ve.htm
Fuel ( cone ) aftermarket as well as grinding stocker discussion http://1stgen.org/viewtopic.php?f=4&t=9847
Competition:
VE injection pump tests http://1stgen.org/viewtopic.php?f=4&t=9585
Electrical:
Dealer installed tach on non I/C trucks http://1stgen.org/viewtopic.php?f=30&t=9861
VSS speed sensor wire route and pin locations for 92 and 93 trucks http://1stgen.org/viewtopic.php?f=30&t=10184&p=75553
Some wire diagrams for 1993 trucks http://1stgen.org/viewtopic.php?f=30&t=11477
89-91 Voltage "pulsing" issue solved! viewtopic.php?f=30&t=15828
Body:
AC cycling switch repair viewtopic.php?f=30&t=17949
Conversions:
Return to Sticky Links
