cheap monster turned money pit ;)
Re: cheap monster turned money pit ;)
Postby motorwood » Thu Apr 19, 2012 5:50 am
Gonna put the old girl on the dyno today.
'03 2500: utility body stock; '92 350 flatbed: maxed fuel, 354 spring, 6x.016's, 14mm H/R, 2.8plate, studs, springs, A1000 5/8 line, Super40 = 454hp 1080tq all fuel. Have added S3 66/74/.91, O-rings, home port job, Steedspeed t-4 manifold. Hp=437/857 :( 13mm P, 5x.025, he551+ht80 843hp 1thousand something trq. Broken 5th gear.
motorwood
Postby dazedandconfused » Thu Apr 19, 2012 6:04 am
Good luck hope you break 500
Postby motorwood » Thu Apr 19, 2012 1:02 pm
400hp 1063trq turbos pull great down low but too small on top end.
motorwood
Postby motorwood » Fri Apr 20, 2012 6:23 am
This has been an interesting journey. I have spent a lot of time and money but have never bested my 455 1080 put down with a super40 on a stock manifold. Granted the gate was pinched and that dyno run was over 2000* on the pyro and ruined bearings and compressor. What we have now cools a maxed out 14mm, makes gobbs of torque, bit just won't HP much past 400. It would sure tow nice though :) I may bump the timing up from 24 to 29 before I dismantle these twins. I have an HX60 that should make a nice partner to either the 40 or s366.
motorwood
Postby JQmile » Fri Apr 20, 2012 10:16 pm
Something weird going on....no way you should be able to keep the EGTs down on a 14mm at 400rwhp. You do a compression test? Might have hurt something.
JQmile
Postby motorwood » Mon Apr 23, 2012 6:16 am
Keeping EGTs "down" is sort of relative. It maxed around 1700* instead of 2100* and we were only running it up to 2800 rpm. I'm gonna put a gated housing on the h1 and replace the the 366 with an Hx60 this week.
motorwood
Postby motorwood » Wed May 16, 2012 4:27 am
Put the hx60 on over the h1e. Dynoed at only 412 and 9?? Trq. I think the backpressure of the h1 is hurting the top end. Put the s366 back on and it feels great and only makes about 12lbs less boost than either set of twins. Thinking about putting the Hx60 over the s366. Should be interesting. Sure would like to crack that 500 fuel only barrier.
motorwood
Postby ahale2772 » Wed May 16, 2012 6:04 am
looks like you have a ton of time into chasing 500...
interesting how KTA did 480 on a 12mm head, 62/71, and 6x18's, yet thew 500hp mark has been such a tough nut to crack
Postby ahale2772 » Wed May 16, 2012 6:11 am
BTW awesome job on the input!!!! If you ever want to make another I'll be first in line!!! frekin cool!
Postby motorwood » Thu May 17, 2012 6:39 am
Thanks. I didn't mean to give the impression I made the shaft itself. I just did the work to the bearing cover and got the right parts to the right machinist. I've though about putting a couple shaft/cover packages together, just dont know if people will want to pay $12-1300. For Getrag parts.
BTW got the Hx60 over the s366. It feels powerful! Need to do some bracing then maybe a dyno trip. Seat of the pants has been less than accurate for me lately :)
motorwood
Postby ahale2772 » Thu May 17, 2012 1:27 pm
What housing and exh wheel on the 66?
Think i may try compounds if my 5x18's are too much fuel
63/68/.91 over something...
Postby motorwood » Fri May 18, 2012 10:09 am
.91 ungated. 73mm
motorwood
Postby motorwood » Sat May 19, 2012 7:11 am
Gonna pull tonight. Hx60 366 twins. Didn't get to dyno. Should be interesting as it feels pretty strong and pulls about 80lbs boost.
motorwood
Postby motorwood » Mon Sep 10, 2012 6:07 am
Pulled the cam out, gear was working it's way off the cam messing with timing. Putting in a drop in cam and I guess I'll be leaving the VE brother hood :/
motorwood
Postby AHineman » Mon Sep 10, 2012 6:16 am
:cry:
