Lug nut options size and flat issues
Re: Lug nut options size and flat issues
Postby bmoeller » Sat May 12, 2012 3:36 pm
PB BLASTER THE HELL OUT OF THEM, if they haven't been off in a long time. Been there, done that.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby Eric_M » Mon May 14, 2012 12:03 pm
bmoeller wrote:PB BLASTER THE HELL OUT OF THEM, if they haven't been off in a long time. Been there, done that.
Done yesterday, will see what happens when I get home tonight.
91 D350 5spd stock a little rough around the edges and needing some work but it should drag my 87 4runner around great!
Eric_M
Postby Eric_M » Tue May 15, 2012 2:40 pm
They all came lose! A 3/4 breaker bar and a pipe did wonders! The sad part is I have to give them back so I might have to go and find my own.
Eric_M
Postby Eric_M » Tue May 15, 2012 8:59 pm
Well I spoke to soon :( 2 lugs are seized on the studs and the studs are spinning. Now to wait until Friday and go after them with a cutting wheel. So far I have only mangled one with a chisel and it still will not split!
Any recommendations for replacement studs? And hopefully they will still fit the hole correctly and actually lock in there.
Eric_M
Postby Tacoclaw » Wed May 16, 2012 2:28 pm
If you're feeling frisky it may be easier to pull the axle, take off the spindle nuts and hub, then grind off the backside of the wheel stud and drive them through that way. That's typically the way we do it on our big trucks, and it saves you from potentially mangling your wheels.
Postby dazedandconfused » Wed May 16, 2012 3:09 pm
Tacoclaw wrote:If you're feeling frisky it may be easier to pull the axle, take off the spindle nuts and hub, then grind off the backside of the wheel stud and drive them through that way. That's typically the way we do it on our big trucks, and it saves you from potentially mangling your wheels.
Ive done this and works well.
Postby Eric_M » Thu May 17, 2012 10:50 am
That maybe what happens, looks like I might have to find out what size the spindle nut is. Oh well. Will have to take it all apart to fix it anyway.
Eric_M
Postby dazedandconfused » Thu May 17, 2012 11:55 am
The spindle nut i just pull the lock clips and usually can get it loose with a small flat nose punch. Thats how ive always done them anyway.
Postby CumminsPower59 » Thu May 17, 2012 12:07 pm
It's either 2 9/16" or 2 5/8", can't remember off the top of my head...one of the two though ;)
Postby ellis93 » Thu May 17, 2012 1:45 pm
dazedandconfused wrote:The spindle nut i just pull the lock clips and usually can get it loose with a small flat nose punch. Thats how ive always done them anyway.
Yep^^^
I did the same till I bought the correct rounded hex socket
Poor folks have poor ways :lol:
Postby dazedandconfused » Thu May 17, 2012 2:55 pm
Yep^^^
Yeap improvise with what you have. ;-)
Postby PToombs » Thu May 17, 2012 5:06 pm
2 and 9/16 socket.
Postby Tacoclaw » Thu May 17, 2012 5:30 pm
The ones on my truck have been taken off many times with just a cold chisel. They don't look real pretty afterwards, but they still work so who's counting?
A drift would leave much less damage, and the correct socket would be even better, but nobody's gonna think you're cool if they walk up and see you using them. ;)
Postby CumminsPower59 » Thu May 17, 2012 7:53 pm
I can't remember wich ones, I usually scab both from work for the evening/weekend and use them. Being a cheap ass and having a cool boss works out, he lets a few of us borrow shop tools to use at home occasionaly, or just work in the shop after hours. Being a quality employee has its perks :mrgreen:
Postby ellis93 » Thu May 17, 2012 8:18 pm
CumminsPower59 wrote: Being a brown nosing employee has its perks :mrgreen:
:jumpsmile:
