Got on the dyno at TS this weekend....
Postby cstalnaker » Sun May 20, 2012 2:45 pm
http://www.youtube.com/watch?v=7i71rUwTfwU
Thanks to the guys with the blue p-pumped 1st gen for taking the pictures for me. Results, 327/700.
1992 W350, built pump by Mountaineer Diesel timed to the head, DDP100-150hp injectors, Industrial Injection 64/14, low pressure piston lift pump, DE 4in. tbe, dana 80, a dump bed, and third gen wheels.
cstalnaker
Re: Got on the dyno at TS this weekend....
Postby oldestof11 » Sun May 20, 2012 3:43 pm
Looks and sounds sweet man!
Do you have an auto or manual? Dyno in OD or direct gear?
Postby cstalnaker » Sun May 20, 2012 4:17 pm
It's got an NV4500. I wasn't allowed to drive it and he ran it in fourth. I don't know what's best, I've heard the more load the truck is under the better power. You'd think that in fifth the load would be increased but I don't know.
cstalnaker
Postby PToombs » Sun May 20, 2012 4:32 pm
You had to pull the duals? Looks like there is plenty of room on htere for them. 5th is way more load. Some operators don't have a clue.
Postby cstalnaker » Sun May 20, 2012 4:43 pm
I decided to pull the duals, that's a little less weight and it only took me about 5 minutes to pull them. I wish I would've gotten on the dyno beside me, I liked that guy a lot more but the dyno was in use when it was my turn. There's always another day to dyno.
cstalnaker
Postby dazedandconfused » Sun May 20, 2012 5:05 pm
All dynos i have been on pull in direct. I miss Dunbar's mobile dyno.
Postby cmann250 » Sun May 20, 2012 5:39 pm
dazedandconfused wrote:I miss Dunbar's mobile dyno.
Yes! Me too. I spoke with him for an hour outside my hotel at SDX. I vaugely knew who he was at the time, but at least I didn't make a fool of myself :lol: I may have been feeling extra chipper by next year and embarassed myself on that dyno :lol:
CS- Do you have any more specs on those sticks?
Postby oldestof11 » Sun May 20, 2012 8:03 pm
Garmon is bought that dyno and put it in the ground. :shock:
Postby dazedandconfused » Mon May 21, 2012 9:03 am
Yrah i saw when Jeff got it.
Postby cstalnaker » Mon May 21, 2012 10:30 am
I really wish I did. I have searched forever trying to find what size they are. It's like they're hiding it. They fuel great but are smokey and hot.
cstalnaker
Postby cmann250 » Mon May 21, 2012 11:00 am
I think they are DDP3's and IIRC Kasper Cummins found that they are 5x13s, but he's changed his sig somewhat recently
Postby Tacoclaw » Mon May 21, 2012 4:00 pm
Wouldn't running in a gear besides 1:1 screw with the readings? I get that it loads it more, but wouldn't the gearing mess with anything? If they're taking a tach signal off the engine it may not, but something will be off at the wheels. :?
Postby oldestof11 » Mon May 21, 2012 4:40 pm
Depends on the dyno.
An inertia dyno calculates your HP based on the fact of how fast you accelerate the drum, which is a set weight. In OD, you can build boost and hold the boost longer to help get a nice power curve.
A load cell dyno applies a brake to help change the load. The more brake, the more load. Those are best run in 1:1 as the brake can be changed to help find your best HP.
Torque is calculated from the HP @ certain RPM. That needs a pick-up signal.
Postby JustinRhodes » Mon May 21, 2012 5:56 pm
No problem on the pictures, We liked seeing the 1st gen on the rollers.
JustinRhodes
Postby bmoeller » Thu May 24, 2012 8:06 pm
Dave sold the dyno, huh? :( I've been on it twice. :D Same truck too. :D I had a video of it, but lost it somehow. :(
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Return to Competition
