Banjo bolt dimensions?
Postby Begle1 » Mon Nov 19, 2007 5:48 pm
The banjo bolts that fit into the fuel filter part of the block and IP fuel inlet are metric, right?
I'm in the middle of a major metropolitan area and NOBODY has metric barb fittings.
Postby PToombs » Mon Nov 19, 2007 6:10 pm
Try a hydraulic supply place. Hoses and such. They should have metric fittings. Maybe NAPA.
Postby JD730 » Tue Nov 20, 2007 5:28 am
I've never seen a metric fitting that when right to a barb, not saying they don't make it. They do make them from 12mm to 6AN and then you use a 6AN to barb fitting, usually a push loc style.
I know Glacier has stuff like that, Summit also has them, only problem is most are aluminum.
The thread is 12mm x 1.5
Mike
The "Rattle Box"
JD730
