Pro 52?
Postby Begle1 » Mon Nov 19, 2007 5:25 pm
ford69557ci wrote:i think i read somewhere that KTA was makin some power up close to 4k maybe a little over??
I think he's so far off the charts that it doesn't really count...
He was making quite a bit (I think ~400 HP), but there was still a pretty radical drop-off. And he had 6%$-something to start with.
It'd probably be better to have an extra gear than worrying about over 4000 RPM.
Postby ford69557ci » Mon Nov 19, 2007 7:28 pm
i think he is also using the stock cam and the 1st gen 12v has the smallest cam outa all of the 5.9L. so maybe if a larger cam was run the power could have been up a little on the top?
ford69557ci
Postby DTanklage » Mon Nov 19, 2007 9:03 pm
do you know any of the specs?
know them
DTanklage
Postby ford69557ci » Mon Nov 19, 2007 9:38 pm
not on the stockers but when i get to the shop tommorrow i will get the specs on my max spool2
ford69557ci
Postby DTanklage » Mon Nov 19, 2007 10:30 pm
those numbers wont mean anything right now cuz i dont have anything to compare them to
ya know?
i want them just the same - cam specs should have its own sticky!
DTanklage
Postby ford69557ci » Mon Nov 19, 2007 11:08 pm
well there are only a few aftermarkets available and most of the sellers or manufacturers wont give up the specs so unless people have already purchased them it is hard to get the specs. thats kinda the bad part about some diesel shops no info unless your payin. but shafiroff gave me all the right setup for my gas motor by e mail for nothin.
ford69557ci
Postby DTanklage » Tue Nov 20, 2007 12:18 am
oh yea...
did he sell ya a 3/4 race cam for $700
lol
rof
lmao
this whole diesel thing is a joke
"quackspoolII" - that really tells me a lot....
like i said, we need the stock specs too
you are the man aaron
put a wheel on yours and post the stockers
DTanklage
Postby KTA » Tue Nov 20, 2007 9:41 am
Yep thats about right down 150hp by 4000rpm from 3400. The problem is not the cam, but the fuel pump at 12000 strokes per minute the fuel pump has virtually no fill time and therefore loses a bunch of flow and power. When I get back to the shop I will get out my cam book and look up the stock cam specs for yall.
Postby DTanklage » Tue Nov 20, 2007 10:07 am
actually, at 4 grand the cam is only at 2k rpm so the lift pump would be making 4k strokes, and only 2k of them would be intake strokes
but still, thats 33.3 intake strokes per second
now ya see why i did all that piston lift pump research?
say "one, one thousand" out loud and you will see that a second is not as short as one would think, but still, that pump has to have available fuel or forget about it
that is why i say you ought to have big lines, big fittings, and the big piston
if you could post the stock cam specs it would be greatly appreciated
don
DTanklage
Postby Begle1 » Tue Nov 20, 2007 11:12 am
I think he's talking about strokes per minute on the injection pump.
One stroke per every two cylinder revolutions... Stroke per minute is three times the engine RPM.
Postby DTanklage » Tue Nov 20, 2007 11:25 am
oh, he called it a 'fuel pump' so i figured he was not referring to the ip
huh?
huh?
please explain
(better)
the ip is driven off the camshaft
the cam spins at 1/2 of the crank speed
should does the ip
DTanklage
Postby DTanklage » Tue Nov 20, 2007 12:42 pm
ps - the cyl does not revolve
DTanklage
Postby ford69557ci » Tue Nov 20, 2007 5:12 pm
Thanks KTA i would like to know the stock specs i have to call the friend i got my cam from cuz he forgot to give me a card i wonder if when he bought it it even came with one?
ford69557ci
Postby DTanklage » Tue Nov 20, 2007 5:24 pm
ohhhh
thats right...
i remember josh telling me that his didnt come with a card
i told him there was no way in hell i would ever put a cam in my motor that i hadnt checked out the card first
much less pay 700 bucks for it!
there was no card in the box aaron
i'll bet ya 20 bucks
sneaky little boogers
arent they?
DTanklage
Postby ford69557ci » Tue Nov 20, 2007 5:26 pm
well i got it from a friend who was building a 96 its the smae guy i got my stoopid pump from so he might have the card i just dont know how to get ahold of him hise wife turned off his cell phone :violin:
ford69557ci
