Got a gas 4wd but can I pull it home on a dolly?
Postby Diesel » Tue Jun 26, 2012 7:31 pm
Got a 93 gas 4wd. It's a it needs tons of work and needs to be towed home. Is it too wide for a car dolly? Rather pull it on a dolly than a trailer.
1991.5 D250 Intercooled A518
Diesel
Re: Got a gas 4wd but can I pull it home on a dolly?
Postby ellis93 » Tue Jun 26, 2012 7:45 pm
Unless it has oversize tires it will,just will. Other than not having one why wouldn't you want to haul it on a trailer.
Postby Diesel » Tue Jun 26, 2012 8:07 pm
Exactly I don't have a trailer and rental Dolly's are real cheap. So the width of the truck won't keep me from loading her up onto a dolly?
Diesel
Postby ellis93 » Tue Jun 26, 2012 8:26 pm
Nope,should fit fine.
Postby Farmboy » Wed Jun 27, 2012 12:40 pm
I would make sure Tranny and T-case are both in neutral.
Farmboy
Postby Diesel » Wed Jun 27, 2012 4:06 pm
Will do. Should I just pull the driveshaft on the rolling axle? I know neutral in the case is all that matters but I just want the smoothest ride possible.
Diesel
Postby bmoeller » Wed Jun 27, 2012 5:36 pm
Only 4 bolts on 2 straps holding the end of shaft on.............
Stop regularly to check the straps. They WILL stretch/settle in. Been there, done that, with a '79 Lincoln Continental. :lol: Had to stop at every rest area on the way home. :roll: Didn't drive over 55 either. Long frigging drive (200 mi)!
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby Mark Nixon » Wed Jun 27, 2012 6:19 pm
GET THE INSIDE MEASUREMENT ON THAT DOLLY!
Also have the seller measure the full width of the front tires, bulge and all.
I have an older Demco dolly and it will NOT load even a 1/2 ton pick-up on it.
Postby Diesel » Thu Jun 28, 2012 9:16 am
Dolly is 82" between fenders. How wide is a 4wd?
Diesel
Postby Mark Nixon » Thu Jun 28, 2012 10:02 am
It should be close to your D-250's width.
