WILL MY NEW COMBO WORK?? PUMP TURBO???
Postby agcododge » Tue Jul 17, 2012 7:11 pm
Wanna get some feedback on a setup in my puller..
14mm ve pump..4000rpm
5x18 sticks
66-74-90 no waste turbo
.94 lines
150 airdog
head is flowing real good..
Motor is fresh...
Should i change injectors or turbo???
Can i go bigger??
agcododge
Re: WILL MY NEW COMBO WORK?? PUMP TURBO???
Postby oldestof11 » Wed Jul 18, 2012 4:11 am
I don't know if the lines are necessary.
However, another 1st Genner on DTR/CompD (SmokinAce) has bigger injectors and it is running HARD!
Postby agcododge » Wed Jul 18, 2012 4:30 am
charger bigger too??
agcododge
Postby agcododge » Wed Jul 18, 2012 4:32 am
planning on sled pulling only..
agcododge
Postby ahale2772 » Wed Jul 18, 2012 8:41 am
thats pretty much as big as you want to go, that should be a good high rpm setup
Postby Kasper Cummins » Wed Jul 18, 2012 7:09 pm
4000 rpm's sounds like alot for a 14mm
92 W250 club cab
Kasper Cummins
Postby agcododge » Wed Jul 18, 2012 7:48 pm
Thats what it will pull (4000 rpm) ..New pump from schieds.
Just pulld it for 1st time hook and ran into a egt issue....2300 egt.......
I better add some water..
agcododge
Postby agcododge » Wed Jul 18, 2012 7:49 pm
turbo is a ed turbo.. I hear good things about these..
agcododge
Postby ahale2772 » Wed Jul 18, 2012 7:52 pm
ED builds a good turbo
Postby oldestof11 » Thu Jul 19, 2012 2:10 pm
I would be interested in hearing your boost numbers. 2300* seems high for a S366...
Postby agcododge » Thu Jul 19, 2012 5:48 pm
low 30s.................
agcododge
Postby oldestof11 » Thu Jul 19, 2012 5:50 pm
Could you get a tighter exhaust housing on that turbo?
I would think for the fuel, you should be 40+.
Postby agcododge » Thu Jul 19, 2012 5:57 pm
im pullin again next week and will try another run...Then im thinkin i may have to change size...
agcododge
Postby JQmile » Thu Jul 19, 2012 8:03 pm
I'd like to see a 66/68 on that truck. Turbos love rpm, but VE's are pretty limited. I'd check timing too. I say 50+ on boost. Nice to see another 14mm truck out there!!
JQmile
Postby agcododge » Fri Jul 20, 2012 4:32 am
Any ideas on where i should have the timing????????????????????
agcododge
Return to Competition
Users browsing this forum: No registered users and 73 guests
