9000lbs stock diesel
Postby dgosney » Tue Jul 31, 2012 3:02 pm
Hey guys there is a pull in marshall MO saturday and they have a 9000lb class. I wanted to ask you guys if I should put 2000lbs in the bed or just run stock weight. Im kinda worried about that much extra weight, seems like it would be that much more prone to breaking something.
dgosney
Re: 9000lbs stock diesel
Postby oldestof11 » Tue Jul 31, 2012 5:59 pm
I consistently run stock as I am not setup to prevent axle wrap. I weigh in 6100-6200 lbs with a 1/4 tank. I have pulled about 7 times and haven't broke anything yet.
At a 9k lbs class, if they allow it and you want to weigh in at the weight, put 1000 lbs out in front.
Postby Hansen01 » Tue Jul 31, 2012 6:01 pm
I hang 1000 on mine if i have that many available weights
depends on if you want to win or just have fun :lol:
I dont know that i would really want to hang 2000lbs on the front though
Under construction...
Hansen01
Postby dgosney » Tue Jul 31, 2012 6:12 pm
We cant hang weights on the front, we can only put them in the bed. As far as the fun part goes ive been having fun but it would be more fun to win lol
dgosney
Postby oldestof11 » Tue Jul 31, 2012 6:55 pm
In the bed, in the cab under the seats, under the air filter, under the battery tray... There are ways to put weight more towards the front and not have hanging weight.
Postby dgosney » Tue Jul 31, 2012 7:10 pm
Well this group of guys really watch whats going on and they are going to check me since this is the first time i will be pulling with them. I thought about all that but when i heard they will be checking im not going to waste my time trying to hide it
dgosney
Postby stillsmokin » Thu Sep 13, 2012 9:03 pm
There was talk over in this part of the country about a 9000lb class a few years back. It pretty much got shot down in flames, a few crew cab ford guys were crying they couldn't drop down to 8500. Turns out they were too lazy to empty the sh-- out of the truck, thus the class isn't needed. Can't believe it really exists somewhere.
9000lbs is an open class weight, since you're up against tractors, semis, and whatever else runs hard.
FWIW, I would need 2300lbs of iron on the puller to hit 9000lbs and that would put me 200lbs under the max load rating of my gooseneck trailer. That will also probably put you over the 4500lb weight rating of a dana 60, so be careful.
92 W250LE REG CAB, SLED PULLER, S400
93 W350LE EXT CAB, dually, 5 speed
stillsmokin
Return to Competition
