Project ugly duckling
Re: Project ugly duckling
Postby ellis93 » Tue Jul 10, 2012 7:26 pm
Nether do I dazed, ive an 82 c10 that I have been tinkering on for the last 6yrs. Out of that time ive maybe spent 6months on it. I deserve a face palm for that :lol: I just can't seem to get motivated :roll:
Postby ahale2772 » Wed Jul 11, 2012 7:40 am
the AC in my 94 died 2 weeks ago, line rubbed through.
so at this point, they both ride the same, the 89 is more enjoyable to drive with the 5 speed, steering in the 89 is better, AANNNNDDDD its got vent windows, big pluss when its hot an both trucks dont have ac.
But i get what you mean, its nice to be able to "down" one truck and do the job right.
Postby PToombs » Wed Jul 11, 2012 5:51 pm
Alex, get some JB Weld and patch the line. That's what I did on mine. I just sanded it, brake cleaner, and put the goo on. I did bend the line away so it doesn't rub. ;)
Postby dazedandconfused » Sun Aug 12, 2012 5:57 pm
Well i stumbled across another roller that is supposed to be rust free so i may go look at it on the upcoming weeks.
Postby dazedandconfused » Mon Sep 24, 2012 2:22 pm
Well ive been gathering info on ifs front suspension setups like the mustang II and newer crown vic setup. My question is do you guys know any older Chrysler cars that would work?
Postby RumbleFish » Mon Sep 24, 2012 4:34 pm
They use volare setups in hot rods, like they use the mustang 2. I havent heard of them using anything else from mopar land. The volare uses a transverse torsion bar setup, and everything else uses a longitudinal torsion bars.
Postby dazedandconfused » Mon Sep 24, 2012 4:37 pm
Yeah i was told about that today from another guy. I had no idea what a volare was and never seen one. Need to measure some more to see if a Crown Vic unit will work.
Postby dazedandconfused » Mon Oct 22, 2012 1:02 pm
Well for the first time since June i fired the Duck up today. Went out and threw a battery in it and it stumbled a few times but started and ran rough gor a minute then cleared up. Took her around the block a few times and parked her behind the shed for the winter. I noticed the lift pump is leaking along with the return line to the trans. If i ever finish that other pos on my driveway i found another body for it.
Postby dazedandconfused » Wed Jan 23, 2013 6:07 pm
Okay so back at dropping money on her. I picked up a new battery yesterday and a core 47RH today.
I got everything for $250 which i was happy about.
Postby cmann250 » Wed Jan 23, 2013 6:12 pm
OOOOOOOOO, parting with a 518????????
You did good, I had a starter and flex plate in my pile of parts for a bit more.
Postby dazedandconfused » Wed Jan 23, 2013 6:23 pm
I may eventually part with the 518. Right now I have a 727, 518, and 47RH. :mrgreen: I think with 27" tires a 307 rear and the 47RH it should be a fun cruiser with good fuel mileage.
Postby 88Centurion » Wed Jan 23, 2013 6:31 pm
Wish I could have gotten that good of a deal on mine. And I'm in the same boat but my 518 is from a gas and I also got a 318 I got to do something with.
88Centurion
Postby dazedandconfused » Wed Jan 23, 2013 6:38 pm
Well the guy posted it for sale months ago and just kinda fell off the Earth. He finally got back with me a few days ago.
Postby 88Centurion » Wed Jan 23, 2013 7:03 pm
Ah well I had a really hard time finding one. I actually found a listing for an engine and called to see if he still had the trans.
88Centurion
Postby dazedandconfused » Mon Jan 28, 2013 3:08 pm
This is the main reason I've been looking for a cab. You can tell in the pic but cab has separated under the drip rail and when you drive in the rain water runs into the cab.
That water runs out of these two holes inside where i barely pushed on the skin and my fingers went threw.
