Dual feed VE
Postby cummins king » Sun Dec 02, 2007 10:15 am
hey KTA
do you really think that your ve case pressure with the 14mm drops below 60 psi, because if it dont the a areomotive a1000 pump would be a waste of time,
and do you have the return line hooked back up or do you just use the return on the injectors
oh and kta any christmas spesials on the 14mm
thanks
93 4X4 auto
cummins king
