Dirtfloorfab's DEM suburban/pickup conversion and 12v swap
Re: Dirtfloorfab's DEM suburban/pickup conversion and 12v swap
Postby ellis93 » Tue Sep 04, 2012 6:13 pm
dazedandconfused wrote:
PToombs wrote:Nope, the cat is real partial to it for some reason. :mrgreen:
So Jon will put a bottle up his rear for a certain price and you put vaseline up yours for the cat? :shock: :lol:
Postby dazedandconfused » Tue Sep 04, 2012 6:24 pm
OMG that is so wrong. :lol:
Postby bighroder » Tue Sep 04, 2012 8:42 pm
Picked up my motor tonight it gets to spend the night in the trees due to unexpected tractor problems I hate it when stuff you take for granted bites you in the ass
86 suburban/pickup conversion project "Dont Even Matter"
Dana 60, 14bff, 12v ve, nv4500, np205
http://1stgen.org/viewtopic.php?f=32&t=13252
bighroder
Postby PToombs » Wed Sep 05, 2012 5:15 pm
Oh Thank God, we're back on subject! :mrgreen:
(I'm not answering Ellis' post because I can't think of anything with less than a 2 X rating :lol: )
Postby bighroder » Wed Sep 05, 2012 5:38 pm
we are all wearing big boy pants, just dont put xxx on the thread lol
bighroder
Postby ellis93 » Wed Sep 05, 2012 5:38 pm
:mrgreen:
Postby dazedandconfused » Wed Sep 05, 2012 6:02 pm
What was wrong with the tractor?
Postby bighroder » Wed Sep 05, 2012 6:18 pm
dazedandconfused wrote:What was wrong with the tractor?
It only gets used by my grandpa so he knows all the little tricks to it it's a 40s case I drained a bunch of crap out of the carb filled it with gas and he came over to run it, the system is 6v and the battery is 12 so you have to f with the thing to get the starter to kick out...the front end was floating with the engine on the hook even with 300 pounds of me standing on it (the front that is)
And ellis I didn't catch that it's been a long day
bighroder
Postby bighroder » Wed Sep 05, 2012 6:57 pm
Getting her out of the tree with the sketchy boom
Safe inside in the harley stable (I'm not gay so dont ask me if the one with ape hangers is mine, it's my dads) mines far left and my chopper I hand built is grey tank on the right
bighroder
Postby revemup15 » Wed Sep 05, 2012 8:11 pm
RC is making 414hp on ic flow honed injectors... the record breaking hp for non ic was 415or 416hp... its doable for sure .... idk if that recored for the non ic injectors were flow honed also... fyi
94 p-pump
revemup15
Banned
Postby bighroder » Wed Sep 05, 2012 8:22 pm
I'll most likely end up ditching them for 5x16s or equivalent after I get the truck going I'm trying to stay in budget while it isnt drivable I'll add later as i go
bighroder
Postby bighroder » Tue Sep 25, 2012 5:39 pm
So I opened the ip up yesterday was kinda disappointed the fuel pin was already turned but the diaphram was detached from the pin
nut and washer still there just chillen tho anyways is there any way to tell how much the star wheel has been turned already? I didnt want to turn it 1.5 if it already had been?
bighroder
Postby PToombs » Tue Sep 25, 2012 5:43 pm
It doesn't matter how far it has been turned, it's a tuning device, you turn it to where you get the best results. If you step on it and it smokes like a pig, turn the starwheel up a turn or 2 until it smokes less or you get it where you want it. If it's all the way down it will go full fuel at 10-15 psi of boost. Starwheel up higher it takes more boost before it lets it fuel.
Postby bighroder » Thu Sep 27, 2012 6:58 pm
that Makes a little more sense I turned up my buddys pump on his 8.3 powered toter so I think I know enough to be dangerous now
bighroder
Postby PToombs » Fri Sep 28, 2012 5:38 pm
You'll fit right in here with that attitude! :lol:
