I'm thinking about becoming a heretic. ;)
Postby meby » Mon Oct 01, 2012 3:11 pm
I'm in the process of selling my reg. cab 2wd for a 4x4 extended cab. At this point not having an extended cab makes it really hard to haul my growing family with in the truck. I'm conflicted about buying a 1st gen v. a 2nd gen because of the flip down seats v. a bench (seats two v. seating three or four in the back). I guess what i'd like to know is their a size difference from a 1st gen to a 2nd gen in the extended cab part. Namely, could I add a bench seat to the first gen and make it work?
Thanks guys,
-Matt
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Re: I'm thinking about becoming a heretic. ;)
Postby dazedandconfused » Mon Oct 01, 2012 3:16 pm
Ive seen guys put the seats out of ext. cab Fords in the back of the first gens.
Postby RumbleFish » Mon Oct 01, 2012 4:35 pm
If you actually plan to use the back seat, get a truck with a bench seat in the front.
Postby oldestof11 » Mon Oct 01, 2012 4:44 pm
Ike, Cummins 59, has a bench in his from a Ford obs.obs.
Postby meby » Mon Oct 01, 2012 7:23 pm
That would be slick. I really would like to stay with a 1st gen. I've not owned an extended cab of either 1st or 2nd gen, so didn't know if it was possible to fit a bench back there.
I found one with an W-350 extended cab aluminum flatbed that I have my eye on, if I can sell mine fast enough. Yippee!
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby CumminsPower59 » Tue Oct 02, 2012 4:26 pm
Jon, Matt, I didn't go the Ford bench seat route, ended up finding an aftermarket bench seat that was originally designed for 1stgen club cabs. It works ok, had to fab up some secure seat belts. but I will pull it out eventually and try the Ford bench seat. The rear bench that I found would have to come out of a 97-0? F150 (roundish trucks) as the bottom/base is only 16" deep, where most rear bench seats are 20". The backs are separate from the bottom, and it attaches to the rear cab wall, and is short enough to fit well in the dished section of the lower rear window trim. Just some fab work and you'll be in like flynn!!! :mrgreen:
Postby meby » Tue Oct 02, 2012 4:55 pm
I will keep that in mind. Thanks
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby RumbleFish » Tue Oct 02, 2012 6:52 pm
I did some quick measuring, and might look into a 88-98 chevy truck rear bench.
Postby meby » Wed Oct 03, 2012 4:09 am
Thanks, options are always good.
-Case 530 CK
www.ebyfarmsllc.com
meby
Users browsing this forum: No registered users and 73 guests
