revemup15 wrote:... going to figure out why it pressurized my rad..... what could i have done wrong for the hg to pop again?
bgilbert wrote:revemup15 wrote:... going to figure out why it pressurized my rad..... what could i have done wrong for the hg to pop again?
Did you surface the deck of the block and or check for straightness?
It's been so long since I've done a hg, this may be a dumb question. But can the hg move a little while setting the cylinder head down? When I did my firering job, I used the cherry picker to slowly set my head down..
Oil cooler issue?
revemup15 wrote:So.... i was farting around and thought well lemme see if my thermostat is bad.. so i took everything apart and to my suprise there wasnt a t-stat!
