Bought a replacement truck
Re: Bought a replacement truck
Postby meby » Sat Nov 17, 2012 5:09 am
I'll check. I got new air and fuel filters.
I don't like running boards either, but it will have to wait until after my the new baby comes.
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby PToombs » Sat Nov 17, 2012 6:48 pm
Matt, what are you doing in my garage? :lol: It may be the accelerater pump or the adjustment, but usually the pump. Pretty simple to change too.
Looks like the running boards didn't save the rockers any, figures!
Postby meby » Sat Nov 17, 2012 7:59 pm
PToombs wrote:Matt, what are you doing in my garage? :lol: It may be the accelerater pump or the adjustment, but usually the pump. Pretty simple to change too.
The drivers side is worse than the passenger. It don't look like much in the picture, but its not to bad overall.
Is the accelerator pump available at parts shops? Also, do you guys know if it has a D44 or a D60 front axle? I need to change a tie rod end and was hoping there was way to find what it has without scraping off and inch or crud. :D
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby dazedandconfused » Sun Nov 18, 2012 5:41 am
Bill had told me on here that if it has balljoints its a 44 and kingpins its a 60.
Postby meby » Sun Nov 18, 2012 6:23 am
dazedandconfused wrote:Bill had told me on here that if it has balljoints its a 44 and kingpins its a 60.
Thanks, I'll check.
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby CumminsPower59 » Sun Nov 18, 2012 8:33 am
It has a 44 in it, easy way to tell is just looking at the hubs. If they are small, then its a 44. That and its stamped on the front of the diff housing usually on the lower left or right side next to the cover (can't remember exactly), if you are looking directly at the front of it.
Postby ellis93 » Sun Nov 18, 2012 8:52 am
Only way I've got an accelerator pump was in a carb kit.
Postby RumbleFish » Sun Nov 18, 2012 9:45 am
Most w250 gassers had a 44. Some even had a lame semi-floating 9.25 8lug rear, but the majority had a 60 in the back. In 84 I think the 60 should have had the big selectro external locking hubs. On the upside, you don't have the trouble some CAD axle that appeared in 85 or 86, assuming it hasn't been changed.
Postby CumminsPower59 » Sun Nov 18, 2012 10:06 am
Jeff you are right as the 60's had selectro's up to and including 89. I believe 90 on ups got internal hubs, i.e., warns, etc.
Postby meby » Sun Nov 18, 2012 3:51 pm
CumminsPower59 wrote:It has a 44 in it, easy way to tell is just looking at the hubs. If they are small, then its a 44. That and its stamped on the front of the diff housing usually on the lower left or right side next to the cover (can't remember exactly), if you are looking directly at the front of it.
I think its a 44 - it has 44-something stamped on the right side of the pumpkin.
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby CumminsPower59 » Mon Nov 19, 2012 5:21 am
Matt, you are right. The 3/4 tons that I have seen with 44's in them have Dana 44 HD's in them, not much difference in standard half ton 44's other than 8 lug hubs...
Postby meby » Mon Nov 19, 2012 6:25 am
The back does have a D60. I checked last night.
I got a Borgeson shaft on order too! 8) The slip coupler was the worst i've ever run across - almost a quarter turn slop in the steering wheel.
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby meby » Mon Nov 19, 2012 3:30 pm
What's red-line on these trucks? I put a tach in it today and it seems like it howls by the time I hit 3000 rpm.
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby PToombs » Mon Nov 19, 2012 5:47 pm
So put in a 4k spring.
:jumpsmile:
Postby meby » Mon Nov 19, 2012 6:07 pm
PToombs wrote:So put in a 4k spring. :jumpsmile:
I would love to. :mrgreen: Think a the one for the ve will work?
-Case 530 CK
www.ebyfarmsllc.com
meby
