skilletky wrote:the ksb advances the timing to aid in cold weather starting. it is wired to a temp switch that is located on the intake plate, which operates the grid heater also. the sensor and ksb power is supplied with power from the second wire coming from the fss. this is for a intercooled truck, not sure about non intercooled
Tacoclaw wrote:The KSB on my non-IC'd truck runs through the intake air temp switch. I personally don't see a problem with wiring it key-on since it takes some time before it actually heats up and retards the engine. That span should give the engine time to start running right.
Mark Nixon wrote: my bad.
Sutter1stgen wrote:I don't know if it matters???? But with the m&h spacer installed, I was at 14 degrees with the pump to the head at idle. And with the ksb flipped on i was at 21 degrees at idle. This was checked with a light.
