input shaft,broken teeth
Postby dodge1stgen » Thu Dec 06, 2012 9:09 pm
This is the second time in the last couple months that i broke teeth off on the input shaft.The bearings are all tight,just wondering if I am setting it up wrong.The truck is my work truck,so its hooked to a trailer more than its not.Thanks Eric
93 250 ext cab p pump injectors 2 disk clutch 3'' charger nv 4500 retired
92 350 ext cab 5 spd 366 spring bd injectors hx 35 dana 80 flatbed
92 350 converter built trans bd fuel pin flatbed/dumpbed
dodge1stgen
Re: input shaft,broken teeth
Postby bubba » Mon Dec 10, 2012 4:38 pm
I would probably stop dumping the clutch with a load haha...
But seriously which transmission is it? The splines that go into the clutch or inside the transmission?
1992 Dodge W350 CTD A518 DRW Flatbed
bubba
Postby dodge1stgen » Mon Dec 10, 2012 6:22 pm
Its a 360,the gear inside the case.
dodge1stgen
Postby bubba » Fri Dec 14, 2012 9:23 pm
I was hoping somebody else would chime in because I'm an engine and auto transmission man, never fooled with sticks too much and certainly not that 360. The first time it happened what all did you replace?
bubba
Postby dodge1stgen » Sat Dec 15, 2012 6:39 am
New input,all new bearing and syncro's
dodge1stgen
Postby bubba » Sun Dec 16, 2012 6:52 pm
It could be a defect of some sort in either the mating gear (to the one that stripped) or the shafts. None were scarred or bent or damaged in any way were they?
bubba
Postby MMiller » Fri Dec 21, 2012 9:35 pm
You did not replace the cluster that meshes with the input gear? Of all the failures I've repaired in the Getrag, the input gear is not one of them. Check and make sure the countershaft bearing races do not move around in the case. I had one that the bearing spun in the case, making the bore too large, and then the countershaft could move up and down. It had failed twice, in low miles, and was repaired by two other shops before I found the bad case. That could cause improper mesh with the input gear.
MMiller
Postby dodge1stgen » Tue Dec 25, 2012 8:23 pm
I didn't put new bearing on the bottom shaft this rebuild ,but the last one i put all new bearings.We checked out the bottom shaft when we had it apart and didnt notice anything wrong,not to say we didnt miss something.
dodge1stgen
Return to Transmission
Users browsing this forum: No registered users and 81 guests
