Oil circuit to allow O/D in any gear?
Postby Begle1 » Fri Dec 14, 2007 10:25 am
I just got off the phone with a Suncoast builder who notified me that it was possible to put an oil circuit in a 4-speed transmission that would enable overdrive in any gear.
Anybody else know that? I sure wish that I was notified of that by the guy who took my order. Don't know when I would ever use it, but it sounds like a handy feature...
Re: Oil circuit to allow O/D in any gear?
Postby flashgordon » Fri Dec 14, 2007 10:44 am
Begle1 wrote:I just got off the phone with a Suncoast builder who notified me that it was possible to put an oil circuit in a 4-speed transmission that would enable overdrive in any gear.
You would have to make sure that over drive was A++++++designed to hold 1st and over drive :shock: :mrgreen:
flashgordon
Postby Philip » Fri Dec 14, 2007 10:46 am
I hadn't heard of that before.
Postby JD730 » Fri Dec 14, 2007 11:49 am
Why?????
Lets crunch some numbers shall we.
Gear ratios for auto as follows
1st 2.45:1
2nd 1.45:1
3rd 1.00:1
OD .69:1
Ok, lets take those number and apply the .69:1 overdrive ratio to them.
1st gear becomes 1.69:1 An advantage? I don't know.
2nd gear becomes 1.0005:1, no real advantage here.
I don really see an advantage doing something like that.
Mike
The "Rattle Box"
JD730
Postby flashgordon » Fri Dec 14, 2007 12:55 pm
JD730 wrote:Why?????
1st 2.45:1
2nd 1.45:1
3rd 1.00:1
OD .69:1
Hmm thanks Mike, for painting a better pitcher of it..........................
I guess if you need a taller axle gear to launch better or some thing......and you only raced 1/8 mile,,and never made it into over drive.......there might be a benefit to it.
As far as spitting gears, looks like you would need smaller overdrive ratio.
Interesting thought just the same ;)
Flash
flashgordon
Postby JD730 » Fri Dec 14, 2007 1:13 pm
flashgordon wrote:As far as spitting gears, looks like you would need smaller overdrive ratio.
Yes, the .78:1 ratio found in the gear vendor unit would work much better.
It would give 1st a 1.91:1, 2nd a 1.13:1, 3rd a .78:1 and OD would be .54:1
Mike
The "Rattle Box"
JD730
Postby flashgordon » Fri Dec 14, 2007 4:20 pm
Yeah, it sure work well with my standard :mrgreen:
Flash.
flashgordon
Postby Begle1 » Fri Dec 14, 2007 5:02 pm
I don't see why you'd ever use it, especially since with any power it would probably destroy something, but it would be cool to have the ability. And you could say that you had a 6-speed.
Return to Transmission
