Ain't that just the CUTEST thing!
Re: Ain't that just the CUTEST thing!
Postby Mark Nixon » Sat Dec 15, 2012 7:34 pm
Diesel wrote:I had that engine in a mini skid steer. They won't start like a cummins so plan on using glow plugs to start but they work. I rarely hit the grids on my truck but with the kubota you have to use glow plugs or its not starting!
Musta' had a junker in that S/S.
This one fired right off after I bled the fuel supply and got the injectors bled out.
No glow plugs necessary and it was 30 degrees out.
Postby Diesel » Sun Dec 16, 2012 10:04 am
It was high hours and needed tons of cranking if you didn't hit the glows. It's good to know that low hours they start up without the glow plugs.
1991.5 D250 Intercooled A518
Diesel
Postby Mark Nixon » Mon Dec 17, 2012 7:13 pm
Was just poking around on Ebay and ran across this:
http://www.ebay.com/itm/MOTORCYCLE-QUAD ... 3d&vxp=mtr
Postby PToombs » Tue Dec 18, 2012 6:02 pm
$270 is cheap! The Kubota turbos for the 3 cylinder ones are $1500 and are only a little bigger. That's pretty cool, lets see, what do i have around here that needs a turbo............EVERYTHING! :lol:
Postby RumbleFish » Tue Dec 18, 2012 6:16 pm
What DOESNT need a turbo??
Postby Mark Nixon » Tue Dec 18, 2012 6:20 pm
PToombs wrote:$270 is cheap! The Kubota turbos for the 3 cylinder ones are $1500 and are only a little bigger. That's pretty cool, lets see, what do i have around here that needs a turbo............EVERYTHING! :lol:
LOL, I hear that!
Let's see, if I were into mini-pulling, what would need to be changed for one of those engines to live at, say, 25HP with twin turbos?
Connecting rods, for sure, I'm told.
O-ring and head studs, I'm thinking.
Valve springs.
The fan would be a disaster waiting to happen.
Injector work?
Dammit, now I need to DISSECT one to see what makes it tick! :evil:
Postby bmoeller » Tue Dec 18, 2012 6:26 pm
That turbo is a cute little chit. :lol: :D
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby CumminsPower59 » Tue Dec 18, 2012 8:24 pm
I have seen that turbo mounted on a 2007 Arctic Cat 700 diesel atv, it was freaking cool, really helps out apparently. I was looking into getting an AC 700 diesel, and I wanted to see if there were any mods to be done to it to help it run a little "better" ;)
