Rear drums
Rear drums
Postby DALEDOZER » Fri Jan 12, 2007 6:25 pm
How do you remove a drum with the brakes hanging up? I don't know how it happened, but all of a sudden the left rear drum brake will not release like the parking cable is hanging, but I still can move the cable in and out by hand.
DALEDOZER
Re: Rear drums
Postby TWorline » Fri Jan 12, 2007 8:32 pm
DALEDOZER wrote:How do you remove a drum with the brakes hanging up? I don't know how it happened, but all of a sudden the left rear drum brake will not release like the parking cable is hanging, but I still can move the cable in and out by hand.
Dale:
It takes a very small screwdriver to push the self adjuster outwards towards the brake drum then turn the star wheel up to loosen up the brakes.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby DALEDOZER » Sat Jan 13, 2007 7:28 am
Thanks Tim, I could not even see the arm thats holding the wheel in place, I'll take another look.
1992 250 4X4, 5spd, HX40, 435s, 3200 gov. Snow Perf. Stg.2, 6" stacks, 4" skyjacker lift, 315 Yokahama Geolander M/Ts, borgenson shaft, piston LP, 7.3 intercooler.
DALEDOZER
Postby dpuckett » Sat Jan 13, 2007 12:28 pm
Dale, you have to get a bent screw driver (Or I use a bent tire plug tool) to get behind the adjuster. Just have to slide the screwdriver along and feel your way in the dark. Then hold it out while you adjust the starwheel looser with a second screwdriver. Then the drum should slide off.
Daniel
Postby PToombs » Sat Jan 13, 2007 2:53 pm
Dale, grab the cable where it goes to the backing plate, and rotate it around, like a jump rope. If it's stuck there, it will usually release some. Good luck!
Postby DALEDOZER » Sat Jan 13, 2007 9:39 pm
Dont try bendin a screwdriver without heat or you'll be down one screwdriver and have another punch, guess that could be good. You can just barelly get a small screwdriver on the lever to back the wheel off, but it worked. Cables were hung up inside drum, just did a complete brake job in the spring with new cables and thier already givin me problems. Dirt roads are hell on vehicles. Thanks for the info guys.
DALEDOZER
Postby PToombs » Sun Jan 14, 2007 4:36 pm
It's more likely moisture and installer error!
Did you put the plunger in? Does it work?
