cummins king wrote:im probaly taking my ic out and my budy isnt putting one in, i dont think
JQmile wrote:Finally got some gauges, hitting about 28psi and 1400 degrees on the pyro. Not sure why EGTs are so low (non intercooled truck)? Testing was in cool air at sea level which I am sure helps......
KTA wrote:The 1st gen has the same piston oil coolers as any 5.9cummins up till the common rails in 2003.
KTA wrote:When my truck was single turboed it would regularly see 1800deg on the strip. I have never melted a piston. Your injectors, timing, and overall fueling can effect how much heat the piston can take, and of course how long the heat lasts 10 sec wont kill a piston but 30 will!
