cmann250 wrote:When I'm not relying on my truck frequently, I have a Suncoast converter waiting to be installed. Eventually I'll post up my impressions. Here's my theory: At a relatively stock level, you may not be able to tell the difference between a $400 and a $700 converter. If you're well over 400 hp and your truck is in the 12s (i.e. BC847), I suspect the difference is beyond noticable. It's a theory of margins. The more expensive converters are better, no doubt. However, whether you and/or your vehicle are under the marginal level is up to you. It wouldn't be the first time an "inferior" product worked
FWIW, I'm cheap, yet I have had really good luck finding deals on normally not cheap parts. Examples: Cummins low pressure piston pump, Suncoast converter, and turbos
Sutter1stgen wrote:You would be Suprised at how much of a difference a good aftermarket converter will make on even a relatively lightly modified truck. I've had my Specrite from 220hp, 255hp, 330hp, 350hp. Definitely worth it. When it was first installed the feeling was awesome. Truck had the perfect stall, cruised well, and when you tipped into the throttle it would rev to the well position stall speed. Then it would set you back in the seat.
cmann250 wrote:Sutter1stgen wrote:You would be Suprised at how much of a difference a good aftermarket converter will make on even a relatively lightly modified truck. I've had my Specrite from 220hp, 255hp, 330hp, 350hp. Definitely worth it. When it was first installed the feeling was awesome. Truck had the perfect stall, cruised well, and when you tipped into the throttle it would rev to the well position stall speed. Then it would set you back in the seat.
Hmm I guess that's why I call it a theory. I should get my act together get that Suncoast unit in
Diesel wrote:Im gonna play devils advocate and say that sometimes when an inquiry is asking too many questions (not sure what you asked) it can be a turn off to businesses. Back on topic: I haven't tried their converters and would love to find out more as well. Thanks for making this post.
