Home Build, Nozzle Tester
Postby therabbittree » Mon Feb 11, 2008 6:33 pm
I'd liek a copy of these too therabbittree@juno.com thanks.. my buddy has one for older vws and we were looking to adapt a different line nut for a cummins or tdi etc..we never did it though..
Later
Deo
therabbittree
Postby doublel89 » Tue Jul 22, 2008 11:26 pm
if you've still got em i'd appreciate it if you sent it to lukelundy89@hotmail.com
91 3/4 Ton 4x4, 5.9 Cummins,DDP Fuel Pin I usually leave it out though, DDP 40 Horse Sticks, HX35W And 2nd Gen Intercooler, Single 5'' Trunout, NV5600 Swap, Dually Conversion, 3.08 Rear Gears, Soon A Custom Hauler Bed
doublel89
also like a copy
Postby lzpoor » Sun Jan 18, 2009 1:51 am
lzpoor
smoke screw?
found one
Postby lzpoor » Sun Jan 18, 2009 12:12 pm
lzpoor
smoke screw?
Re: found one
Postby swank » Sun Jan 18, 2009 11:36 pm
lzpoor wrote:http://mercedesshop.com/shopforum/showthread.php?t=224334
Plans to build using a bottle jack
Darn good find! Thanks for posting the link. Is this similar to the setup you have plans for, Scott?
truck
swank
Re: Home Build, Nozzle Tester
Postby mumbles » Tue Feb 07, 2012 11:56 am
clicked on the link and it said it was no longer there :( if somebody could email the plans my email is lild359@gmail.com
"The Rattler" 86' Chevy C-30 350 an a 3 speed smash an mash
mumbles
Postby Billy Bones » Sun Jan 13, 2013 3:15 pm
Billy Bones
Postby directinjktn1stgen » Sun Jan 13, 2013 3:39 pm
1992 w250 4x4 4" custom turbo back exhaust 5x.012 HVLP lift pump 3200 181/210 M3 fuel pin, gated hx35 auto important meters
Jeffery
http://i1259.photobucket.com/albums/ii5 ... af0c34.jpg
directinjktn1stgen
Postby draginmopars » Sun Jan 13, 2013 3:42 pm
some one sent me this pic last year.
using a port-a-power pump
Works great for me, just unscrew hose, install fitting, ready to go.
No more than I use my port-a-power.
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby directinjktn1stgen » Sun Jan 13, 2013 4:11 pm
it that hydraulic fluid u run through it ?
Jeffery
directinjktn1stgen
Postby draginmopars » Sun Jan 13, 2013 4:20 pm
directinjktn1stgen wrote:it that hydraulic fluid u run through it ?
yes,
I don't think it changes the pop pressure.
the hydraulic fluid viscosity appears close to the diesel fluid
I am looking for all 6 of them to be the same..
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby directinjktn1stgen » Sun Jan 13, 2013 4:56 pm
gotcha not a bad idea there i like i give three thumbs up :cheers: :salut: :thumright:
Jeffery
directinjktn1stgen
Return to Cool projects YOU can do
