bmoeller wrote:With juice brakes, having to pump it up, doesn't always mean it has a leak. If no visible leaks, manually adjust the shoes up properly.
RumbleFish wrote:bmoeller wrote:With juice brakes, having to pump it up, doesn't always mean it has a leak. If no visible leaks, manually adjust the shoes up properly.
Or delete the abs!
bmoeller wrote:With juice brakes, having to pump it up, doesn't always mean it has a leak. If no visible leaks, manually adjust the shoes up properly. Then, see if you still need to pump them up with the pedal. Sometimes that all that is needed.
