building atleast 400hp
Re: building atleast 400hp
Postby RCCUMMINS89 » Thu Jan 24, 2013 4:39 pm
Stomp made more power with 5 holers
'nuff said?
Postby cmann250 » Thu Jan 24, 2013 4:48 pm
RCCUMMINS89 wrote:Stomp made more power with 5 holers
'nuff said?
Are we talking #2 deezul or drugs? West coast numbers? Dunbar's dyno? :lol: :lol: :lol:
In the efforts to keep this one on track...
vefummins wrote:I have marine bowl pistons so spray pattern shouldn't be an issue.I was going to go thru cpp.if not the 7x11s what about 5x16s.I really don't want to run twins if I don't have to
If you hope to tow at 400 hp with a VE, twins are the way to go in my conpletely uneducated and ignorant opinion. Is a single possible, yes. Power will be smoother and more useable with twins.
Postby oldestof11 » Thu Jan 24, 2013 4:53 pm
'nuff said?
And Jason made the most with some 5x25's. :cheese:
I read a lot about people having 7 holes and switching to 5 or 6 to net not only more power but better driveability.
Postby revemup15 » Thu Jan 24, 2013 5:48 pm
Just run garden hoses into the cylinders and let er feed
94 p-pump
revemup15
Banned
Postby RCCUMMINS89 » Thu Jan 24, 2013 6:50 pm
Yep 7 hole is crap.... but don't tell that to the people have 7 hole injectors.
It's kind of like telling us 1st genners that electronics on the new trucks are good and make more power. We just say no in spite.
Postby vefummins » Thu Jan 24, 2013 7:13 pm
Ok well I'll scratch the 7 holes then.how much is it to get injectors flow honed.what companies make good injectors under 700$
vefummins
Postby vefummins » Thu Jan 24, 2013 7:30 pm
And I dont tow.I just want to try a single first and if I need to I will do the twin set up
vefummins
Postby RCCUMMINS89 » Thu Jan 24, 2013 8:09 pm
Well, we have some 5x14 contagious sticks going off right now to get flow honed. Should have before and after flow readings from it within the week hopefully. Flow honing starts off at $150 (depending if other stuff needs work)
So, anyone can technically buy bosch nozzles that have been edm'd to their wanted size for around $300 and have them then flow honed and installed per their requested pop pressures for $150... being into their own custom set for under $500.00
Postby vefummins » Thu Jan 24, 2013 10:10 pm
Are daps any good.Ive been doing some research and people seem to like them.and I'm liking the price of them
vefummins
Postby RCCUMMINS89 » Thu Jan 24, 2013 10:14 pm
I don't know anything about the injectors... their nozzles tested out good.
Postby vefummins » Thu Jan 24, 2013 10:21 pm
I like this site.you guys respond fast and give good info.the cummins forum was just full of people wanting to blow smoke. Could you tell me what exactly a timing spacer is? And what is a ksb?
vefummins
Postby RCCUMMINS89 » Thu Jan 24, 2013 11:21 pm
A ksb is a device that advances our timing during low operating temperatures to cut down smoke....
A timing spacer allows more timing piston movement. So basically it gives you a broader range of dynamic timing. Stock pump timing has a rough timing sweep of about 6 degrees and the spacer adds about 3 more degrees.
Postby fatty » Fri Jan 25, 2013 7:40 am
Those of you that have never run 7 hole injectors should not be giving advice about said injectors.
Postby ellis93 » Fri Jan 25, 2013 10:15 am
fatty wrote:Those of you that have never run 7 hole injectors should not be giving advice about said injectors.
4 real
I read this here on bla bla doesn't count as knowledge,it only would count if it was actually tested by you.
If you wanna throw out second and third hand accounts then I have one for you,people than run their wonderful hooty tooty 5 holers cant work their trucks with any turbo with and inducer smaller than 62mm,all they can do is go fast,blow smoke and show their collective a$$es. Me I chose the 7hole injectors because I use my truck to haul heavy chit around,my truck and trailer alone grosses 11,5. I don't need my truck running volcanic egt temps trying to pull a hill. Truck alone I can't touch 1200° on the pyro,hauling I have to watch it but its controllable. Oh and no idle haze to gag and choke on.
I'll probably get flamed over this little book but hey....if we're all giving opinions... Theres mine ;)
all opinions are like buttholes,everyone has them and they all stink.
Postby RCCUMMINS89 » Fri Jan 25, 2013 10:30 am
Can anyone name one single person who has made 400hp with a 7 hole injector? Or even 350? THE NAME OF THIS THREAD IS "BUILDING ATLEAST 400HP", not making my truck not haze or hauling alot of weight.
Most of the new 5 hole injectors are coming from CPP and DAP, they are dirty for the MOST PART.
