injector washers affect on timing
Postby ellis93 » Tue Jan 29, 2013 8:06 am
Kinda curious what is the relation between the two. My thoughts are that it would increase it because of the tip being closer to the piston bowl.
A few more thoughts I've had was if you use them how much would it change the egts? Who's got them from where and what would be the best to use? What's the thinnest available?
Re: injector washers affect on timing
Postby cmann250 » Tue Jan 29, 2013 8:27 am
PToombs wrote:Thin ones are .020, thicker are .040, and I've heard that there is a .060 also. If it hazes with a .040, how bad would it be with a .060? :shock:
Postby RCCUMMINS89 » Tue Jan 29, 2013 9:22 am
Well, it doesn't really affect timing. Becuase it doesn't matter where the injector tip is, it doesn't change the relation of where the piston is... meaning the piston is still at whatever btdc. However, it technically does because the fuel would get there .0000000000000000000000000000000000000000000000000000000000000000000001 millesecond faster.
With 7x10s... use the thinnest washers available... Good ol' CPP should have them and I bet that is what you have on yours now anyways.
Postby ellis93 » Tue Jan 29, 2013 10:10 am
I don't have any problems with my injectors,what I do have is bubbles up the sides of them. Not many but enough to say there's a sealing issue,and while they're out I'm gonna pop test them again.
Anyone tried to make them thinner,like sanding them down thinner?
Postby PToombs » Tue Jan 29, 2013 6:07 pm
Ellis, don't do it. No way you can sand them down and keep them even all the way around. 1 low spot and you have a leak.
Or, try it and let us know how it works! Somebody has to be the guinea pig for this siht. ;)
Postby RCCUMMINS89 » Tue Jan 29, 2013 6:16 pm
Just get some from Jamie at CPP
Postby ellis93 » Tue Jan 29, 2013 6:35 pm
PToombs wrote:Ellis, don't do it. No way you can sand them down and keep them even all the way around. 1 low spot and you have a leak.
Well...its probly a turd idea but the injectors are a piece of cake to get out. I was just thinking if 20 is good how would .15 or 10 do.......?
Postby turboram » Wed Jan 30, 2013 5:58 am
i think the thinner that. 020 washers would have a hard time sealing because of not having any crush area. Unless you would have a way to emboss the thinner ones,but I doubt .005-.010 would make enough of a difference if any to be worth it
turboram
Postby DodgeFreak » Wed Jan 30, 2013 11:06 am
perfectly flat table with sandpaper and water with a perfectly flat piece to hold the washer to sand it down...kinda like what they use for valve bodies in a trans shop might do it....I say give it a try.....or if its not perfect put some high temp rtv on both sides.... :lol: :lol: I'm kidding on that btw....
Postby Remps » Wed Jan 30, 2013 11:17 am
The 20s look so thin, it would seem one would have to put 3 or 4 on one injector to equal the thickness of the factory washer.
Postby ellis93 » Wed Jan 30, 2013 11:50 am
This is what I had on my mind
Postby BILTIT » Wed Jan 30, 2013 3:51 pm
Good luck finding a perfectly flat table. When we did lapping/sanding of flat surfaces in a shop we used sheets of glass or special machined pieces of steel.
Derek B.
BILTIT
Postby RCCUMMINS89 » Wed Jan 30, 2013 4:36 pm
Holy ass sthi.... CPP wants 40 bucks for sealing washers? that's about 400,000% mark up.
Ok, get some from Cummins... last time I bought six they charged me a dollar something.
Postby ellis93 » Wed Jan 30, 2013 5:03 pm
It's copper.....how precise does it need to be :lol:
Postby ellis93 » Wed Jan 30, 2013 5:04 pm
RCCUMMINS89 wrote:Holy ass sthi.... CPP wants 40 bucks for sealing washers? that's about 400,000% mark up.
Yep,seen that almost lost sphincter control,:lol:
