PICTURES ON YOUR BATTERY AND CONNECTION TO THE BATTERY
Postby TEXAS_OUTLAW » Mon Aug 27, 2012 9:15 am
I WANA MAKE SURE MINES RIGHT I SWAP THE ENGINE OUT OF MY 93 W250 AND HA VEING SOME CHARGING ISSUES AND LIGHTS PROBLEMS SO PICS OF YOUR BATTERY OF THE STOCK CABLES AND HOW THERE SET UP FOR BE AWSOME THANKS
2008 2500 6 speed 4x4 : EFI LIVE ,South bend dual disc , 4 in to 6 in stack egr and dpf got stolen
1993 w250 5 speed 4x4 : under DEconstrution
1987 k30 4x4 crew cab dually : under construction
TEXAS_OUTLAW
Re: PICTURES ON YOUR BATTERY AND CONNECTION TO THE BATTERY
Postby oldsoul » Thu Sep 06, 2012 8:30 pm
Here are some pics of my set up. This engine compartment wiring was on my list for this winter. Then the main wire running to the starter fell out of the factory connector. Still have to get to the rest of the rats nest.
[img Image
Image Image Image Image
oldsoul
Postby dieselcountry85 » Wed Jan 16, 2013 6:25 am
This is my first 1st gen. Is it only supposed to have one battery? Every other cummins i have owned had two.
dieselcountry85
Postby CumminsPower59 » Wed Jan 16, 2013 6:32 am
dieselcountry85 wrote:This is my first 1st gen. Is it only supposed to have one battery? Every other cummins i have owned had two.
Yup ;) There are ways to mount two, as I have. I have two red top Optima's side by side on a modified stock battery mount. I can post a pic up later this evening.
Postby dieselcountry85 » Wed Jan 30, 2013 7:19 am
Ever come up with a pic of your side by side batterys? I am intrigued as to how to do it.
dieselcountry85
Postby cmann250 » Wed Jan 30, 2013 7:30 am
Hansen01 did this
Postby CumminsPower59 » Wed Jan 30, 2013 8:36 am
Shoot! I totally forgot to post a picture! :oops:
The way that is pictured above is how I mounted mine, but with dual Optima's. I like them because they are a little lighter than two stock lead-acid batteries, and that they are slightly shorter too. I can still work around them if need be.
Postby Hansen01 » Wed Jan 30, 2013 9:46 am
I don't remember why but i changed mine to be parallel with the truck, so you can do it either way
This time however I'm going to put one on each side
Under construction...
Hansen01
Return to Electrical
