Ford cummins
Re: Ford cummins
Postby revemup15 » Fri Nov 23, 2012 9:46 pm
Its been so long since i drove a nv i cant say... they also make short throw shift kits for these as well which is on bottom of the list but will happen
94 p-pump
revemup15
Banned
Re: Ford cummins
Postby revemup15 » Sat Nov 24, 2012 7:59 pm
By the way guys this is a cab and chassis frame... so the axle sits alittle farther back... the plan for the truck is to junk the flatbed and shorten the frame to put a shortbox on it... has anyone of the forums done this and have any tips of doing it... since its a c&c frame it has me puzzled
94 p-pump
revemup15
Banned
Re: Ford cummins
Postby RCCUMMINS89 » Sat Nov 24, 2012 8:28 pm
A what?
Re: Ford cummins
Postby revemup15 » Sat Nov 24, 2012 8:33 pm
Its a cab and chassis frame
94 p-pump
revemup15
Banned
Re: Ford cummins
Postby RCCUMMINS89 » Sat Nov 24, 2012 9:21 pm
Why does it have you puzzled? Meaning what is different in shortening it than any other frame?
Re: Ford cummins
Postby dazedandconfused » Sun Nov 25, 2012 5:06 am
The cab and chassis frame is flat from the cab back and not contoured like a regular truck frame.
Re: Ford cummins
Postby revemup15 » Sun Nov 25, 2012 8:20 am
Daze... is it possiable to shorten to put a shortbox on it? Im not for sure but are they narrower?
94 p-pump
revemup15
Banned
Re: Ford cummins
Postby dazedandconfused » Sun Nov 25, 2012 8:27 am
Its been a long time since ive messed with the Fords. It may be easier to find a F250 shortbed in a salvage yard and chop the frame off under the cab. That would have all mounts and holes lined up and you could graft it on to your truck.
Re: Ford cummins
Postby RCCUMMINS89 » Sun Nov 25, 2012 12:09 pm
dazedandconfused wrote:The cab and chassis frame is flat from the cab back and not contoured like a regular truck frame.
So?????????????????
If you are thinking of shortening a frame you should have the know how or the fabrication skills to be able to figure out how to do it.
Re: Ford cummins
Postby Mustangracer42 » Thu Jan 31, 2013 10:05 pm
What ever came of this swap?
Mustangracer42
Re: Ford cummins
Postby bmoeller » Sat Feb 02, 2013 8:31 am
IIRC, the dually and C&C frames are narrower on them, than the pickup truck versions. IIRC, the frame on the C&C and duallys are 34" wide, vs 38" on the pickups.
The little bit I've driven a ZF5, I think they are comparable in shifting quality to the NV4500.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Re: Ford cummins
Postby RCCUMMINS89 » Sat Feb 02, 2013 8:39 am
Oh my, don't tell Kyle that... he thinks the ZF5 is the best shifting transmission on the planet.
Re: Ford cummins
Postby Mustangracer42 » Sun Feb 03, 2013 7:06 pm
My zf6 clicks like butter with good synthetic fluid
Mustangracer42
Re: Ford cummins
Postby RCCUMMINS89 » Sun Feb 03, 2013 9:16 pm
I've heard they are a really nice shifting tranny. The fastest tranny I"ve ever driven was a getrag though.
Re: Ford cummins
Postby oldestof11 » Mon Feb 04, 2013 3:32 pm
ZF6 are the cats meow to holding power and shifting fast. I havent driven a G56 BUT people who drag race can make stupid times and not grenade them.
