Project ugly duckling
Re: Project ugly duckling
Postby dazedandconfused » Thu Feb 07, 2013 5:01 pm
So i got my new cab thanks to Caleb. I unloaded it out of the truck at work and put it on my trailer. I got it out to the folks now to unload and start working on prepping it.
Does anyone know how to remove the chrome drip rail molding without destroying it? I would like to remove it to sandblast and maybe reuse.
Postby RumbleFish » Thu Feb 07, 2013 5:35 pm
Andrew removed some and put it on his drw. I think I may have heard of a trick usuing a can opener?
Postby Hansen01 » Thu Feb 07, 2013 8:57 pm
Chrome drip rail cover???? I wan!, Anyplace make them?
Under construction...
Hansen01
Postby dazedandconfused » Sat Feb 09, 2013 10:54 am
Cabs off the trailer and on the cart now.
Postby dazedandconfused » Mon Feb 18, 2013 12:56 pm
Picked up a seat today for the truck. I have to fab up some mounts for the seat.
Im waiting for warmer weather to start blasting the cab. This is the blaster i bought the other day.
Postby cmann250 » Mon Feb 18, 2013 2:54 pm
How good of a compressor do you need to run that sand blaster? I'm going to need one soon.
Postby dazedandconfused » Mon Feb 18, 2013 2:59 pm
Well we have a 5hp old Coleman that's about as tall as me so i hope it keeps up.
Postby cmann250 » Mon Feb 18, 2013 3:08 pm
Hmmm looks like I'll be a bum and work on it at the farm like usual. The compressor at the house could not run a DA sander for more than 5 min.
Postby dazedandconfused » Tue Feb 19, 2013 10:04 am
Yeah it wouldn't run this then. I just payed for my wheels and they are being shipped. Question for you guys though. Given the choice would you convert the D71 with 3.07 gears to 5 lug or the 3.55 D70 under it now? Im leaning towards the 3.07 but if it grenades can i install 3.55 gears in that housing.
Postby skilletky » Tue Feb 19, 2013 10:38 am
id keep the 3.07. i wish i would have kept it when i had it. do they make that style wheel to run on 8 lug? it would be alot cooler if they did.
skilletky
Postby dazedandconfused » Tue Feb 19, 2013 10:48 am
Nope i have to change it to 5 lug.
Postby skilletky » Tue Feb 19, 2013 11:39 am
do you just put different hubs on it? or is there more to it?
skilletky
Postby ellis93 » Tue Feb 19, 2013 11:46 am
Andy I have same kind of blaster,they take a lot of air to use them. I have a 120gallon 10 horse compressor and that thing will cycle every 4 or 5min using a blaster like that.
Postby dazedandconfused » Tue Feb 19, 2013 12:59 pm
Ive got access to a tow behind compressor as well so hopefully it will all work out.
Postby oldestof11 » Tue Feb 19, 2013 4:14 pm
Personally, I would sell the 3.07 and get a 9" or 8.25" Ford axle with some upgraded axle shafts.
