txs wrote:Caleb, if you dont have bad hot spots or heat cracks or much scoring, i use a DA with 80 grit on flywheels, this has always worked well for me.
Glad to see someone else does things simple like me
ellis93 wrote:txs wrote:Caleb, if you dont have bad hot spots or heat cracks or much scoring, i use a DA with 80 grit on flywheels, this has always worked well for me.
cmann250 wrote:Make a cradle out of wood? I figured I'd make a custom wooden trans jack attachment for my floor jack. So essentially the same thing.
Was that some jargon of young folks that you adressed me with?
ellis93 wrote:Would you rather me call you sugar britches
ellis93 wrote:cmann250 wrote:Make a cradle out of wood? I figured I'd make a custom wooden trans jack attachment for my floor jack. So essentially the same thing.
dazedandconfused wrote:Only if you whisper it into his ear.
ellis93 wrote:Well.....
Tiger Lilly work for you then?
